Home » Audio » Home Theater » 5.1 or 7.1?
5.1 or 7.1? [message #71637] Fri, 02 March 2012 12:08 Go to next message
DinosaurDance is currently offline  DinosaurDance
Do you have a 5.1 or 7.1 surround system? Do you think it makes that much of a difference in sound quality, or do you not care either way?
Re: 5.1 or 7.1? [message #71641 is a reply to message #71637] Fri, 02 March 2012 15:09 Go to previous messageGo to next message
Damon73 is currently offline  Damon73
I have a 5.1 system and I like it just fine. One of my friends says that 7.1 is better, but I really wasn't able to tell the difference when I went to his house.
Re: 5.1 or 7.1? [message #71671 is a reply to message #71637] Mon, 05 March 2012 09:22 Go to previous messageGo to next message
Theoretically I think it can make a difference (better imaging, e.g.) but in most houses, I don't think people set things up well enough for you to be able to notice. The difference was pretty small when I upgraded to 7.1.
Re: 5.1 or 7.1? [message #71687 is a reply to message #71637] Tue, 06 March 2012 14:19 Go to previous messageGo to next message
I have a 7.1 system, but that is mostly because I had the speakers on hand. I don't notice or care all that much either way.
Re: 5.1 or 7.1? [message #72184 is a reply to message #71687] Tue, 17 April 2012 02:57 Go to previous message
Since the back surrounds in a 7.1 system are fed the same signal,
Your really talking 6.1 channels.
That said, I have tried 7.1 with movies and found almost no difference. With 6.1 music however, you are talking a great deal of difference. The six channels can all be fed whatever the recording engineer wants.
I'm having a new home built with a 14 x 20 theater room. I plan on having a 7.4 system. With the Three Pi speakers that Wayne Parham has designed, each Three Pi requires a flanking subwoofer. I will end up with 4 Three Pi speakers, maybe 6, and 4 subs, the rear subs will be in each corner. This is not to quadruple the bass, but spread it evenly.
My Pioneer receiver requires 7 speakers before I can switch to THX Music Mode, which I think will be awesome. With movies, there are very few 7.1 sound tracks. 7.1 can fake the two back channels, but I'm mainly interested in 7.1 for music.
Floyd
Previous Topic: Going beyond 1080p?
Next Topic: Plasma or LCD
Current Time: Fri Oct 16 08:54:09 CDT 2026
