Home » Sponsored » Pi Speakers » Grills for Eminence woofers, sound implications
Grills for Eminence woofers, sound implications [message #71343] Fri, 10 February 2012 13:26 Go to next message
Hi all, I've got a pair of pseudo 4 Pi's up and running and they sound great. Man can you crank these things!
Also up and running is my 16 month old son! He has many nick-names one of which is Sir Pokes-a-lot (that used to be daddy's nick-name .. BA-doom Tish!)
Wayne, I remember that pic you posted a few years ago of your little super cool man in sunglasses!
To keep his pokey little fingers off my woofers, what grills would you suggest? I bought some 15" Pyramid grills
GW15BK
http://www.amazon.com/Pyramid-GW15BK-15-Inch-Grills-Brackets/dp/B000DZEN5U
from my local electronics shop for $18 and they seem sturdy enough.
Small problem is that they're not made to fit over the front gasket. So the mounting hardware sits off of the baffle a bit instead of being flush--no biggie.
Are there better grills?
Wayne, have you ever done any testing to see if there are changes to the freq response?
Cheers,
Jeff
P.S. For those with little kids, please see my post over at diyaudio and post your kid's favorite songs!
http://www.diyaudio.com/forums/music/205428-songs-toddlers-young-kids-love.html
Re: Grills for Eminence woofers, sound implications [message #71345 is a reply to message #71343] Fri, 10 February 2012 14:45 Go to previous messageGo to next message
I like using the metal grilles for speaker that are going to be used in clubs, where they are most vulnerable. They aren't very attractive, but they're tough and don't do much to affect the sound.
Grille cloth stretched over an attractive frame is usually more popular for home-hifi speakers, but you do lose some acoustics in the trade for aesthetics. The material is never perfectly acoustically transparent, and some there is some sound reflected back, which causes response ripples from self-interference.
The frequency and amplitude of the ripple depends on the grille material, and on the distance between grille and source. This is the same thing for acoustically transparent screens for theaters. See the post below for an idea of the ripple that results from a screen or grille:
Re: Grills for Eminence woofers, sound implications [message #72267 is a reply to message #71345] Thu, 19 April 2012 20:44 Go to previous messageGo to next message
Hey Wayne,
The graph of the effects of screen reflection starts at 1.8k but the grills are for the woofer which is rolling off at 3rd order by then. Can I assume that I will get negligible effect on the freq. response on the woofers when using the grills?
Cheers,
Jeff
Re: Grills for Eminence woofers, sound implications [message #72292 is a reply to message #72267] Fri, 20 April 2012 20:37 Go to previous message
In general, you can expect the effects to be more pronounced up high, so in general, the answer is yes. But do understand that the anomalies are caused by self-interference between sound coming from the source and sound reflected back from the grille. So the distance between source and grille has an effect. The further away it is, the more the problem shifts downward in frequency.
Previous Topic: Large Rubber "O" Ring with JBL 2226H
Next Topic: Hot Veneer Score: 2Pi Towers Comin' Up!
Current Time: Sat Oct 24 17:20:51 CDT 2026
