Home » Audio » General » Gasket Material Recommended by Wayne P. (You can find it at Lowes)
Gasket Material Recommended by Wayne P. [message #70588] Fri, 23 December 2011 00:58 Go to next message
index.php?t=getfile&id=661&private=0
You just need to ask for Shower Pan Liner. It comes 40 mils thick, and it makes a really tough, flexible, and definitely non-conductive gasket material.
It costs about $20 for two linear feet, and it comes about six feet wide.
You can make a lot of gaskets with that much.
I'm attaching a pic.
Floyd
Re: Gasket Material Recommended by Wayne P. [message #70589 is a reply to message #70588] Fri, 23 December 2011 05:56 Go to previous messageGo to next message
Thanks, Floyd, this is so much better than using caulk, which makes it all but impossible to remove the drivers.
Re: Gasket Material Recommended by Wayne P. [message #70633 is a reply to message #70589] Sun, 25 December 2011 15:18 Go to previous message
I've used that stuff in the lab for gasket material as well. Works well for a makeshift o-ring. Works very well as a covering for keeping chemicals off of homemade wood stands that may be ruined by acid.
Previous Topic: Loud "BANG" From Speakers
Next Topic: Record Store
Current Time: Wed Nov 04 06:58:47 CST 2026
