Home » Audio » Craftsmen » Repairing a Barrel Construction Drum
Repairing a Barrel Construction Drum [message #69085] Fri, 19 August 2011 17:42 Go to next message
Ebirah01 is currently offline  Ebirah01
I just got my hands on a nice, big conga drum shell that uses a barrel type construction to form the shell (strips of wood that stand vertically and are glued together along their long sides to form the drum). These strips are coming apart and I need to glue them back in place before I can re-head the drum. Any suggestions? I am planning on using padded ratchet straps and standard white wood glue, but are there any tips I need to know before I go at it? Thanks!
Re: Repairing a Barrel Construction Drum [message #69173 is a reply to message #69085] Thu, 25 August 2011 03:34 Go to previous message
LizardBat is currently offline  LizardBat
Awesome! That sounds like a great project! Be sure to remove as much exposed dried glue from the planks as possible before repairing it, so that there are no gaps between planks. Using the ratchet straps is good idea, just be sure they don't slip off and you put a towel or something between them and the drum shell.
Previous Topic: Tuning Vents and Resonators
Next Topic: Necessary Tools
Current Time: Wed Nov 25 06:17:10 CST 2026
