Home » Sponsored » Pi Speakers » Signal Wire for 4Pis
Signal Wire for 4Pis [message #68708] Sun, 24 July 2011 17:21 Go to next message
Frihed89 is currently offline  Frihed89
What do people use? I have rewired a number of amps and my CD player signal cables with a various Audio Note (UK) cables (IC cable wires). It make a difference there. I'm not sure with the speakers. Also, the runs are long enough to be costly at AN IC prices! Or should I be using speaker wires?
Re: Signal Wire for 4Pis [message #68710 is a reply to message #68708] Mon, 25 July 2011 08:03 Go to previous message
Use a good stranded copper conductor that's 16 guage or larger. Only use enough to reach the components, and don't leave a bunch of extra coiled up on the bottom. But do use enough to allow slack for easy service - Make sure there's an extra foot or two so you can easily connect the drivers outside the box before installing them.
Previous Topic: SCREWS?
Next Topic: Plans for the 1pi & 2pi please.
Current Time: Sat Oct 24 18:14:32 CDT 2026
