Home » Sponsored » Pi Speakers » dummy load
dummy load [message #68450] Sun, 03 July 2011 07:51 Go to next message
David Morehouse is currently offline  David Morehouse
2- 8 ohm dummy loads = 28.50
shipping to Canada = 33.18
taxes + duty
this is crazy
any alternatives to this?
Re: dummy load [message #68472 is a reply to message #68450] Mon, 04 July 2011 14:15 Go to previous messageGo to next message
Not there, personally, and depends how fancy and what power you want in a load, but something like these oughta get you started and pcX should be in-country shipping unless I'm way off.
http://www.partsconnexion.com/resistors_mills_mrc.html
looks like a 5-buck handling fee...so you're $17 + ship for 50W a side.
FWIW. ( no interest, etc. )
Re: dummy load [message #68476 is a reply to message #68450] Tue, 05 July 2011 06:55 Go to previous messageGo to next message
Thanks. I wasn't bothered by the price of the resistors, it's all the added payouts. It costs more to get the product than the value of the product. Just seems wrong.
Re: dummy load [message #68477 is a reply to message #68476] Tue, 05 July 2011 07:11 Go to previous messageGo to next message
If I paralled a 15 ohm, 50 watt resistor with a 18 ohm, 50 watt resistor would this be an acceptable resistor for an 8 ohm, 100 watt zobel woofer resistor. Or use 2-15 ohm resistors.
Re: dummy load [message #68479 is a reply to message #68477] Tue, 05 July 2011 09:13 Go to previous message
Yes, that will work just fine. Understand that the 15Ω resistor will dissipate a little more power, and get a little hotter. If pushed hard, it would fail first. But if both are 50 watt parts, you'll be able to lean on it pretty hard without getting into trouble.
Oh, and by the way - just an FYI - if a Zobel fails, it won't cause the speaker to blow, it will just cause an annoying upper-midrange peak.
Previous Topic: Start yer day with a shave and 5 Mgs of Valium!
Next Topic: Pi 2 towers with H290 - doable????
Current Time: Sat Oct 24 18:49:01 CDT 2026
