Home » Audio » Thermionic Emissions » Stand alone stereo tone controls anyone?
Stand alone stereo tone controls anyone? [message #9028] Tue, 07 June 2005 19:58 Go to next message
Peter Swartz is currently offline  Peter Swartz
Well my fostex 206's need some low mid and low end help. I hate to add an additional componet to the signal path but.... I need to have a little switchable tone contol unit of high sonic quality. Preferably a tube tone set up or a desceet component set up.
Any sugestions!!!!
Can any of you suggest a vintage ish eq I might consider that isn't going to add noise and destortion?
Thanks for your help, Pete
Re: Stand alone stereo tone controls anyone? [message #9029 is a reply to message #9028] Fri, 10 June 2005 11:36 Go to previous messageGo to next message
Peter,
Good EQs don't add any noise or distortion that you can hear. Try Rane, Ashley or some other brand. Use a prametric EQ. Don;t do any tone cotrols...those are fixed and will almost always distort the signal.
-akhilesh
Re: Stand alone stereo tone controls anyone? [message #9034 is a reply to message #9029] Mon, 13 June 2005 10:59 Go to previous messageGo to next message
Thanks for your input, I've ordered the components from parts express for the correction circuit that Martin recommended. I hope to inally be able to listen to my new 206's by the end of the week. C Ya, Pete
Re: Stand alone stereo tone controls anyone? [message #9035 is a reply to message #9034] Mon, 13 June 2005 12:47 Go to previous message
Sounds good Peter! Please do post on the single driver forum with your experiences as you use the BSC. It will be helpful to all of us!
-akhilesh
Previous Topic: Power Supply suggestions
Next Topic: Plate Choke Miller Capacitance
Current Time: Sun Nov 29 17:35:30 CST 2026
