Home » Audio » Speaker » Have a pair of Full range drivers - what to(should) do with it?
Have a pair of Full range drivers - what to(should) do with it? [message #67498] Sun, 08 May 2011 14:13 Go to next message
Eldragon65 is currently offline  Eldragon65
What's your thought on enclosure type, also should I ad the tweeter and what type of x-over, or should I utilize 'full range?'
Prefer 1-2 cubic/ft sealed enclosure. Thanks!!! (blue line on chart)
index.php?t=getfile&id=381&private=0
BETSY -K:
Re 5.7 ohms
Fs 49.959Hz
Sd 22.966
BL 5.471
Qms 2.798
Qes .548
Qts .458
Spl 94.6
Vas 82.914L
Mms 9.167g
Re: Have a pair of Full range drivers - what to(should) do with it? [message #67499 is a reply to message #67498] Sun, 08 May 2011 16:44 Go to previous messageGo to next message
I can't make out the notes on your attachment. Could you give a brief description of you two different cabinets?
Bob
Re: Have a pair of Full range drivers - what to(should) do with it? [message #67500 is a reply to message #67499] Sun, 08 May 2011 19:44 Go to previous messageGo to next message
here is the site with all the info:
http://www.wildburroaudio.com/speakers.php
Re: Have a pair of Full range drivers - what to(should) do with it? [message #67501 is a reply to message #67500] Sun, 08 May 2011 21:38 Go to previous messageGo to next message
OK. I'm with the program.
You have the Betsy-K. (You did actually buy a pair, didn't you?) You have no options. You will have to use a sealed box. It is remotely possible that it will go into a BR, but it will be huge. Again, you might fit it into a BiB.
The graphs you are looking at were most likely made on an OB. The clue is that the higher Q Betsy goes lower in the bass than the lower Q Betsy-K. This is why you would choose a high Q driver for an OB application. Actually, everything you need to know is on that product page.
Bob
Re: Have a pair of Full range drivers - what to(should) do with it? [message #67503 is a reply to message #67501] Sun, 08 May 2011 23:51 Go to previous messageGo to next message
Thanks!
Re: Have a pair of Full range drivers - what to(should) do with it? [message #67549 is a reply to message #67501] Wed, 11 May 2011 09:42 Go to previous message
"You did actually buy a pair, didn't you?"
Unfortunately yes
Previous Topic: Sub woofer Assist
Next Topic: Good wire article
Current Time: Thu Oct 15 23:06:59 CDT 2026
