Home » Sponsored » Pi Speakers » Rabbet dimensions for flush mounting (4Pi upgraded) (Flush Mounting)
Rabbet dimensions for flush mounting (4Pi upgraded) [message #66970] Sun, 10 April 2011 08:58 Go to next message
blvdre is currently offline  blvdre
Hi All
I'm in the process of having a pair of cabinets built for my 4Pi speakers, and need to know what the correct dimensions would be for the rabbets required to flush mount the drivers. I know that the depth must accommodate a gasket, and the width must allow for a bit of play. I'm using the JBL 2226H and the H290 Horn. Any advice or suggestions are appreciated.
Re: Rabbet dimensions for flush mounting (4Pi upgraded) [message #66975 is a reply to message #66970] Sun, 10 April 2011 12:45 Go to previous messageGo to next message
Here you go:
Re: Rabbet dimensions for flush mounting (4Pi upgraded) [message #66981 is a reply to message #66975] Sun, 10 April 2011 19:34 Go to previous messageGo to next message
Thanks Wayne. So do I need to add to the woofer OD so that it will seat properly? In other words, If the rabbet is as wide as the woofer OD, will it seat OK? I see the horn is a bit harder to pin down, so I will plan accordingly and leave a little wiggle room.
Re: Rabbet dimensions for flush mounting (4Pi upgraded) [message #66989 is a reply to message #66981] Sun, 10 April 2011 23:17 Go to previous messageGo to next message
You definitely do not want a zero tolerance fit when using wood, or even a really tight fit. Give it as least 1/16" extra, and probably better to oversize 1/8". That little gap you leave isn't much.
Re: Rabbet dimensions for flush mounting (4Pi upgraded) [message #66995 is a reply to message #66989] Mon, 11 April 2011 05:41 Go to previous message
Will do Wayne, thanks again for the guidance.
Previous Topic: It's Here! T-2020 Chip Amp
Next Topic: Three Pi & Four Pi Plans
Current Time: Sat Oct 24 18:48:35 CDT 2026
