Home » Audio » General » Room for Imperfection?
Room for Imperfection? [message #66455] Thu, 03 March 2011 08:54 Go to next message
I'm a classic rock fan and often listen to music recorded in the 60s. Frequently you hear more audio artifacts. I actually like that; does anyone else feel this way?
Re: Room for Imperfection? [message #66585 is a reply to message #66455] Tue, 08 March 2011 17:20 Go to previous messageGo to next message
Kaleb is currently offline  Kaleb
That's what makes it so great, it's nostalgic and can't be redone. If music was like that now, I don't think anyone would really "get it".
Re: Room for Imperfection? [message #66588 is a reply to message #66455] Tue, 08 March 2011 18:20 Go to previous messageGo to next message
There has been a Winamp plugin around for about a decade that will simulate the playback of a digital files as it would appear on a vinyl album with noise, clicks, pops, distortions, wow, flutter, rumble and whatever else a record could possibly do. You can even set the year the record would be made and it'll simulate the way vinyl of that vintage sounds. It's freeware.
I think that's the go-to one if you needed it for an effect.
I do something a different so it warms up the signal like a tube amp would, but digitally and when I use headphones I let 10% of the signal crosstalk so it simulates the speakers' sweet spot.
I have another DSP that cleans up the signal and acts like a good pre-amp would. It has a pre-amp, a treble exciter and reverb built in, but I only use the 3-band EQ to get the signal flatter and tighter.
That DSP is added in the output stage and everything is processed at 24-bits and output at 24-bits. It's then converted to analogue with no bit-truncation and output to a power amp. The sound is much closer to DVD-A or HDCD than 16-bit redbook audio, from 16-bit sources.
Analogue would do this stuff a little bit better at ridiculous prices. But the output is so classic sounding, warm and so much more detailed than any analogue source. There are lots of ways to hear the music as intended and to suit your tastes.
Re: Room for Imperfection? [message #66594 is a reply to message #66588] Wed, 09 March 2011 06:50 Go to previous messageGo to next message
I'm going to have to check out that Winamp plugin; I haven't used Winamp in awhile and was unaware of that feature. I love that you can even set the year.
Re: Room for Imperfection? [message #66595 is a reply to message #66455] Wed, 09 March 2011 15:00 Go to previous message
Well, my memory must have failed me or there was an old plugin that did what I suggested.
http://www.winamp.com/plugin/izotope-vinyl/39214
You can set the decade with this one and other things vinyl does to the signal, but not all the stuff I thought it could do.
Previous Topic: Any good podcasts worth a listen?
Next Topic: Books on CD
Current Time: Tue Sep 22 03:08:47 CDT 2026
