| 4 pi, oh my! [message #66242] |
Mon, 21 February 2011 18:14  |
EL Jack
Messages: 5 Registered: February 2011
Esquire |
Just picked up a pair of assembled but unfinished pi4 speakers.
Haven't even begun a thorough "test" but I'm already knocked out by their absolute lack of compression. I'm also impressed with the treble response. Listening to the Heifetz Sibelius concerto on Classic reissue right now - wow.
Currently running on solid state (Arcam) but will get it on my Cary monoblocs soon, so I expect it to even sound better on tubes: which leads me to my question - are these a good load for tubes? (I have the Cary KT-88-based monos, which are 25 watts, switchable to 50 - but they don't have a 4-ohm tap).
My other question is with regard to the cabinet - the person who built them didn't make mirror-image pairs (that is, as I look at the speakers the ports are both on the right). Is this the intended design?
Okay, one more question: do folks put these on stands? I was thinking of 3 inches of maple block and 4 hockey pucks per side.
Again, wow and thanks for bringing this great speaker into the world~!
| Re: 4 pi, oh my! [message #66243 is a reply to message #66242] |
Mon, 21 February 2011 19:07   |
They're a very easy load for tube amps. High efficiency and benign impedance curve. Perfect for tubes.
They are intended to be built and used in mirror images. This is mostly for aesthetics but there is a very small oblique tilt in the position of the forward lobe and the upper and lower nulls. For that reason, I generally suggest the tweeters be outboard. That way the upper null is slightly to the outside and the lower null is slightly to the inside. But it's so slight, it really doesn't matter.
Stands are according to personal preference, but I generally like to suggest that stands be limited to small risers if subs aren't used. This helps reduce floor bounce by keeping the midwoofer/floor distance small. On the other hand, this speaker really works best when used with subs, and in that case, I like to use stands about 9-15 inches. This puts the center of the forward lobe right at listening height. The subs should be blended with the mains, which smoothes room modes, including floor bounce. More about that in the document below:
| Re: 4 pi, oh my! [message #66252 is a reply to message #66246] |
Tue, 22 February 2011 12:48   |
EL Jack
Esquire |
All standard: Eminence drivers and the base crossovers.
I have previously built a small 2-way but the veneer was not entirely successful. I'll need some help to decide what to do, but I'm inclined to go with a basic black paint.
I just can't believe how these things fill the space with no distortion.
After I spend a couple weeks with them I'll do a review on Audiogon as I strongly believe that more people need to be made aware of these.
My guess is that most folks (including me before yesterday) think there'll be some issue with the high frequencies and the cross-over region, but I'm not getting any issues in those places.
I have three other pairs of speakers (Maggies, Meadowlarks, and Polks, former S-phile Class C, B, and C, respectively) but I think these will be at the top of the rotation.
| Re: 4 pi, oh my! [message #66276 is a reply to message #66262] |
Wed, 23 February 2011 08:45   |
Bill Epstein
Messages: 1088 Registered: May 2009 Location: Smoky Mts. USA
Illuminati (2nd Degree) |
I don't know the Omega woofer, only the Delta from the old Theatre 4, but going to the JBL 2226 has to make the bigger change as it's in the music-range, 150 to 1600 Hz. Also, the 2226 has a mid-range that just kills all those darling little 86dB, 6" drivers in the $10,000 speakers I've heard.
The PSD-2002, while not in the class of the B&C DE-250, is very easy on the ears, doing a great job of conveying the timbre of the music.
