Home » Audio » Pro Sound » Audio software for voiceovers?
Audio software for voiceovers? [message #66132] Tue, 15 February 2011 18:33 Go to next message
Reverb is currently offline  Reverb
Right now, I'm an Audacity user. I only use it to record voiceovers. It seems to do what it's supposed to, but I wonder if I should upgrade to some different software. Do any of you record voiceovers? If so, what software can you recommend?
Re: Audio software for voiceovers? [message #66152 is a reply to message #66132] Thu, 17 February 2011 08:58 Go to previous messageGo to next message
There is no point in learning new software. They are all just interfaces for your sound card anyway. Use the Unicode version of Audacity if you are not already.
Audacity has everything. Spending a bunch of money on a package s not going to really accomplish anything. If you have a hard time using the program and are unwilling to learn, that might be a reason to switch.
Re: Audio software for voiceovers? [message #66162 is a reply to message #66132] Thu, 17 February 2011 23:23 Go to previous messageGo to next message
Thanks, those were my thoughts too. If it can already do what other programs can, why get something else? Smile Also, what's the difference between Audacity with the Unicode version?
Re: Audio software for voiceovers? [message #66165 is a reply to message #66132] Fri, 18 February 2011 00:22 Go to previous message
Basically, I forgot to download the UC version once and found that it did not have all the features of the standard version. It's much more developed and feature-rich in my experience.
Previous Topic: Compression on mp3 players?
Next Topic: Placing Microphone Over A Musical Instrument
Current Time: Wed Oct 28 11:59:09 CDT 2026
