Home » Sponsored » Pi Speakers » 3-Pi Speaker plans
3-Pi Speaker plans [message #66124] Tue, 15 February 2011 04:51 Go to next message
johaneriksson is currently offline  johaneriksson
Hi Wayne!
Could you send me a copy of the pi 3 plans and crossover plans. Both regular and upgraded versions if ok.
Regards
Johan
Re: 3-Pi Speaker plans [message #66125 is a reply to message #66124] Tue, 15 February 2011 07:59 Go to previous messageGo to next message
You've got mail!
Re: 3-Pi Speaker plans [message #67043 is a reply to message #66125] Thu, 14 April 2011 00:29 Go to previous messageGo to next message
giverago is currently offline  giverago
Any chance I could get them to? How would a Eminence Delta Pro-12A work in the 3pi? These will be used for a home cinema. Thanks!
Re: 3-Pi Speaker plans [message #67044 is a reply to message #67043] Thu, 14 April 2011 00:45 Go to previous messageGo to next message
for using the 3-pi speakers as LCR behind a perforated screen what you you recommend the crossover be set at? what would you recommend for the surround channels?
Re: 3-Pi Speaker plans [message #67045 is a reply to message #67044] Thu, 14 April 2011 01:20 Go to previous messageGo to next message
Use the crossover shown in the plans. It is optimized and should not be changed. Do not substitute drivers - use only the ones suggested in the plans.
Again, this is an optimized design. If you deviate, you are throwing away literally hundreds of hours of design and test time, and that after a lifetime of study and perfection of this style loudspeaker. I don't want to come across immodestly, but I do want to impress upon you that this isn't just a weekend effort using casually chosen drivers. It is a mature and fully polished design.
For surrounds, you can use one π or two π model loudspeakers.
Re: 3-Pi Speaker plans [message #67046 is a reply to message #67045] Thu, 14 April 2011 01:25 Go to previous messageGo to next message
I understand, i just happened to have those drivers on hand. Will these be able to crossover at 80 hz?
Re: 3-Pi Speaker plans [message #67047 is a reply to message #67046] Thu, 14 April 2011 01:31 Go to previous messageGo to next message
Don't crossover, blend the mains with the subs. Low-pass the subs, but don't high-pass the mains. These speakers won't need the high-pass like you might do in a prosound environment. What you'll gain is better smoothing of room modes.
For more information on this approach, read the following whitepaper:
Re: 3-Pi Speaker plans [message #67049 is a reply to message #67047] Thu, 14 April 2011 01:39 Go to previous messageGo to next message
awesome, can I get the 1 and 2pi plans as well? Do you have the kits in stock? Would the 1pi work as a small centre channel?
Re: 3-Pi Speaker plans [message #67050 is a reply to message #67049] Thu, 14 April 2011 02:05 Go to previous messageGo to next message
Yes, we keep most kits in stock. We have to assemble the crossovers, because there are several options. But we keep a large stock of all the components on hand so we can build any version crossover in just a few days.
As for a center, I would suggest that it be the same as the L/R mains. If this is impractical, go with a phantom center.
Re: 3-Pi Speaker plans [message #67051 is a reply to message #67050] Thu, 14 April 2011 09:03 Go to previous messageGo to previous message
The one or two depending on there size would be for a different room with a much smaller system.
Previous Topic: 4 Pi Speakers and 3 Pi Subwoofer Request Plus Question
Next Topic: In-wall Baffle
Current Time: Sat Oct 24 18:48:40 CDT 2026
