Home » Sponsored » Pi Speakers » 3-Pi using JBL 2206 drivers
3-Pi using JBL 2206 drivers [message #66012] Sun, 06 February 2011 12:13 Go to next message
spkrman57
Wayne,
I acquired a pair of JBL 2206J 12" drivers. I installed them in a pair of JBL L-100 Century cabs. I plugged the original port with foam and took the round wood piece that used to be on the back of the mid drivers sub enclosre and tapped that into place with a hammer since it was tapered just right.
Leaving the tweeter opening intact left approx 3 1/2" dia port that is 1" deep. Winisd pretty much verified what I suspected with a port tuning around 60hz. WT2 verfied my guess being within 1.5 hz of my prediction.
I'm currently running this with my modified 3-Pi crossover running to my JBL 2446/Be diaphrams/500hz Edgar tractix horns powered by a pair of Baldwin Model 40 mono-blocks(6L6G PPP).
I mainly set this up to break in the 2206's which are quite stiff on the suspension just like the 2226's I have used in the past. I have approx 30 hrs so far and they are loosening up nicely.
Wayne, do you by chance have the original plans/crossover for the 3-Pi utilizing the 2206. I know they are yesterdays systems, but I think it is a exciting system with more bass than I had expected.
Regards, Ron
index.php?t=getfile&id=312&private=0index.php?t=getfile&id=313&private=0index.php?t=getfile&id=314&private=0
Re: 3-Pi using JBL 2206 drivers [message #66013 is a reply to message #66012] Sun, 06 February 2011 12:42 Go to previous messageGo to next message
I don't have the plans anymore, but seem to recall they were in the 1.0ft3 to 2.0ft3 range, something like the two π speaker cabinet. Seems like I tuned them around 50Hz-60Hz, something like that.
I tried them with compression drivers and with "more conventional" tweeters like domes and slots. That was the rub for me - the version I liked best was a cone/dome speaker but the three π and up are all "supposed" to be constant directivity designs. So it didn't "fit" in my line. It would have been a great premium version of the one π / two π style bookshelf models though. I used to have a one π model using a JBL 2115 that I absolutely loved for low-SPL "intimate" listening. A three π with the 2206 and a nice high-end dome tweeter would definitely fit that niche.
3-Pi using JBL 2206 crossover? [message #66027 is a reply to message #66012] Mon, 07 February 2011 08:41 Go to previous messageGo to next message
spkrman57
Wayne,
Do you remember the crossover you used for the 3-Pi (2206)?
I'm using a crossover similiar to your current 3-Pi at the moment, but I think it's not behaving like I want.
It does sound pretty decent though overall. I rate things more critically than most.....
Thanks, Ron
Re: 3-Pi using JBL 2206 crossover? [message #66036 is a reply to message #66027] Mon, 07 February 2011 15:18 Go to previous message
The one with the dome tweeter was a lot like the one in the one π and two π speakers. Pretty simple "minimalist" design.
Previous Topic: Eight Pi
Next Topic: 3 pi speaker plan
Current Time: Sat Oct 24 19:03:32 CDT 2026
