Home » Audio » Home Theater » mounting HDTV
mounting HDTV [message #64786] Sun, 21 November 2010 10:48 Go to next message
compguy is currently offline  compguy
I have a very large (55" LCD TV) that I want to mount to the wall above my fireplace. We live in an older house with plaster walls, and I am not sure it will hold. What would be the best way, hardware to mount it without cracking the plaster on the wall?
Re: mounting HDTV [message #64795 is a reply to message #64786] Sun, 21 November 2010 20:43 Go to previous messageGo to next message
NoDirections is currently offline  NoDirections
I would say definitely look for a stud, or even better, two studs in the wall that you could bolt the mount on to. We have paneling in our house and that's how we did it.
Re: mounting HDTV [message #64811 is a reply to message #64786] Mon, 22 November 2010 08:51 Go to previous messageGo to next message
You will definitely need 2 studs for a TV that size. We just installed a 45 (or 47) inch HDTV and there is no way the TV would stay up securely with one stud.
Re: mounting HDTV [message #64817 is a reply to message #64786] Mon, 22 November 2010 12:15 Go to previous messageGo to next message
You can hang it from the ceiling with dental floss (*not responsible for damage my advice may cause)
Or actually, just use the other ideas in the post Smile
Re: mounting HDTV [message #64820 is a reply to message #64817] Mon, 22 November 2010 14:23 Go to previous message
http://www.audioroundtable.com/images/Laughing_Group.gif
Previous Topic: Acoustic Research AR HC6
Next Topic: Outdoor Home Theater
Current Time: Tue Nov 03 09:28:17 CST 2026
