Home » Audio » Silicon Valley » no output on a yamaha rx-385 receiver
no output on a yamaha rx-385 receiver [message #7857] Tue, 18 October 2005 02:32 Go to next message
ricky madison is currently offline  ricky madison
my yamaha receiver comes on but has no output. any help will be appreciated.
Re: no output on a yamaha rx-385 receiver [message #7858 is a reply to message #7857] Tue, 18 October 2005 08:23 Go to previous message
Sounds like it's time to take it to the shop. If you're fairly comfortable with troubleshooting, you might be able to work on it yourself. I'd look for things like internal fuses, and don't overlook the obvious like selector switches. Then check the output transistors or IC.
Previous Topic: class D
Next Topic: Modifications for the Sonic T-Amp
Current Time: Fri Nov 06 03:43:21 CST 2026
