Home » Audio » Silicon Valley » Help! - Converting Constant Voltage Amp!
Help! - Converting Constant Voltage Amp! [message #7815] Fri, 06 May 2005 11:10 Go to next message
Bill Bumplizer is currently offline  Bill Bumplizer
Converting Constant Voltage Amp.
I been given 4 Bogen/Techcraft 250watt amps.
They are constant voltage amps with taps for 70v, 25v out.
Is there a way to convert these amps to a useable output for a standard P.A. System?
Thanks
Ran
Re: Help! - Converting Constant Voltage Amp! [message #7816 is a reply to message #7815] Fri, 06 May 2005 12:59 Go to previous message
Only if you run through a transformer, See link below and check out the specs it gives you examples of how to hook them up.
Previous Topic: Service Manual
Next Topic: Curcuit breaker going off on Yamaha RX-385
Current Time: Fri Nov 06 03:43:25 CST 2026
