Home » Audio » Speaker » XO for OB 2-way (Freebie is gonna cost a lot of money)
XO for OB 2-way [message #62938] Fri, 28 May 2010 09:45 Go to next message
As luck would have it, I was clearing a garage from a rental and found a pair of Ememrald Physics CS2. Not sure what happened, but one of the CD horns is broken (a $15 fix from Parts Express0. Other than that the speakers appear to be new (still in origianl shipping boxes). Great find except the pre-programmed Behringer unit is missing. A new one will run $800, and I sure ain't gonna pay that for a freebie.
How hard would it be to come up with a passive XO for this system? It doesn't need to be dead-on, but close would be nice. I did hook a simple first order XO up just to make sure all the drivers work, and the sound lacked bass and the top end needs to be attenuated.....C
http://www.positive-feedback.com/Issue37/emerald_physics.htm
Re: XO for OB 2-way [message #62939 is a reply to message #62938] Fri, 28 May 2010 10:32 Go to previous message
It looks like a two-way speaker with direct radiating (open baffle) midwoofer, a helper woofer and CD horn tweeter.
If so, the crossover is very similar to what you would do for a box design. The dipole sets the pattern down low and through the lower mids but up higher - where you will want to crossover to match directivity with the horn - the pattern has collapsed beyond that set by the baffle (whether dipole or monopole). The only difference between monopole and dipole at this crossover frequency range is the dipole will have rear-facing output whereas the monopole will not. But the forward facing beamwidth will be the same as a monopole. So you can design the crossover similarly, I would think.
Seems to me the biggest difference will be what happens below the crossover frequency, EQ for the bottom end, etc. Since it appears to have two woofers, I'd low-pass the bottom one so it rolls off around ~200Hz. This will leave the upper one as the midwoofer, and it can be treated similarly to other DI-matched two-way designs. Some would call this a 2.5-way system.
Here's a thread with my design approach. It has a schematic that I hope might help, maybe use it as a starting point.
Here are a few more posts about the basic design philosphy of constant directivity:
Previous Topic: Altec
Next Topic: Multiple Subwoofers
Current Time: Sun Nov 22 05:14:29 CST 2026
