Home » Sponsored » Pi Speakers » 2pi tower Cabinet (what type of wood)
2pi tower Cabinet (what type of wood) [message #62675] Fri, 14 May 2010 20:30 Go to next message
fuj32 is currently offline  fuj32
I am getting ready to buy the wood for these cabinets. What type and size has seemed to work the best for everyone. Or what is a good suggestion?
Re: 2pi tower Cabinet (what type of wood) [message #62676 is a reply to message #62675] Fri, 14 May 2010 20:51 Go to previous messageGo to next message
You can use 18mm Baltic Birch or MDF. We use MDF on most cabinets that aren't used outdoors unless weight is a problem.
Re: 2pi tower Cabinet (what type of wood) [message #62797 is a reply to message #62676] Wed, 19 May 2010 10:55 Go to previous messageGo to next message
Mark Andrews is currently offline  Mark Andrews
Wayne I built my rather crude initial cabinets with 5/8ths ply (16mm) - if I rebuild them as I am now keen to do should I rather use 18mm ply?
I guess the port size has to change then too - will look at plans
Thanks
Mark Andrews
Re: 2pi tower Cabinet (what type of wood) [message #62798 is a reply to message #62797] Wed, 19 May 2010 11:33 Go to previous messageGo to next message
Personally, I'd stick with MDF unless the cabinets were going to be moved a lot, or used outdoors or in high humidity. The biggest advantage of Baltic Birch is its durability and moisture resistance.
Re: 2pi tower Cabinet (what type of wood) [message #62799 is a reply to message #62798] Wed, 19 May 2010 12:25 Go to previous messageGo to next message
Thanks Wayne - I was more concerned about what thickness to go for 16mm or 18mm...?
Ta
Mark
Re: 2pi tower Cabinet (what type of wood) [message #62800 is a reply to message #62799] Wed, 19 May 2010 12:47 Go to previous messageGo to next message
I would use 18mm stock.
Re: 2pi tower Cabinet (what type of wood) [message #62813 is a reply to message #62800] Thu, 20 May 2010 03:54 Go to previous message
Thanks Wayne 18mm it will be.
Ta
Mark
Previous Topic: 3 Pi Plans
Next Topic: 2 Pi Tower Plans Please
Current Time: Sat Oct 24 19:40:02 CDT 2026
