Home » Audio » Home Theater » Do you really need a dedicated subwoofer for a small living room?
Do you really need a dedicated subwoofer for a small living room? [message #99940] Tue, 24 November 2026 02:03 Go to next message
Prince is currently offline  Prince
In most cases, subwoofers are used in large home theater rooms, but I have been wondering how good it can be in smaller ones?  I know that even a compact room can benefit from a better low frequency reproduction, even though I know volume settings are of great importance if one wishes to achieve that.
We have lots of options like products from SVS and other producers that can fit into this, but the major worry of many is whether these subwoofers would disturb the neighbours around. So, I would like to know how you guys handle bass management in smaller places. Do you make use of more than one subwoofer? How do you position them in order to get what you want?
Do you have subwoofers that you can recommend for one who plans to use it in a small room? What are the best ways to get the bass under control without losing the impact?
Re: Do you really need a dedicated subwoofer for a small living room? [message #99941 is a reply to message #99940] Wed, 25 November 2026 00:05 Go to previous message
Clint is currently offline  Clint
I've realised, from my experience running a studio, that having more bass isn't always better.
So, I won't mind beginning with one sub, working on getting the placement correctly, and seeing how the room responds before I decide if adding the second one is necessary.
I don't want to spend money buying what I don't need.
I am okay with the SVS SB-1000 Pro, but the RSL Speedwoofer 105 MKII is also very good. I am obsessed with how sound behaves in a room, so I'd rather get a clean, controlled result than just chase big bass. What room size are you working with?
Previous Topic: Do you like room calibration rather than getting expensive home theater device?
Current Time: Wed Nov 25 17:29:50 CST 2026
