Home » Audio » Craftsmen » Nitrocellulose (Is that what they use on guitars that makes them so shiny and smooth?)
Nitrocellulose [message #61474] Wed, 25 November 2009 15:55 Go to next message
Recently, Bill Epstein suggested that I use nitrocellulose on some speakers I'm having built. I was wondering, is that the finish commonly used on guitars? It's a form of lacquer, right?
The finish I'm looking for is a shiny smooth surface that almost looks like the pearl coat on a car. I really like how it looks on pianos and guitars.
Re: Nitrocellulose [message #61475 is a reply to message #61474] Wed, 25 November 2009 21:11 Go to previous message
You may be referring to French Polish. There's a website with thorough instructions on polishing a guitar if you Google french Polish. Guy has a Latin sounding name IIRC and uses olive oil as a lubricant. I'd find it for you but a certain virus wiped out my ability to search for anything and the registry doctor has been busy.
Previous Topic: Finishing Padauk is a pleasure
Next Topic: Trimming veneer
Current Time: Thu Nov 12 16:56:44 CST 2026
