Home » Audio » Speaker » Fountek Neo CD 2
Fountek Neo CD 2 [message #60406] Thu, 16 July 2009 12:55 Go to next message
jphaggar is currently offline  jphaggar
I need help finding The T/S parameters of Fountek Neo cd 2
Thanks
Re: Fountek Neo CD 2 [message #60409 is a reply to message #60406] Thu, 16 July 2009 14:46 Go to previous message
This is what I found:
- dimensions: 185 x 85 mm, required cut-out 146 x 61 mm oval
- front plate gauge: 4.5 mm
- circular ribbon
- efficiency 95dB (1W/1m)
- top cutoff 40 kHz
- resonance frequency: 300 Hz
- impedance: 7 Ohm
- ribbon dimensions: 8 x 120 mm
- ribbon mass: 0.034 g
- application recommendation: from 2.0 kHz with 12 dB crossover
Previous Topic: Q for AudioFred
Next Topic: AE TD12S
Current Time: Sun Oct 25 08:51:08 CDT 2026
