Home » Audio » General » how to use a multimeter when installing car audio system?
how to use a multimeter when installing car audio system? [message #59801] Mon, 06 July 2009 00:15 Go to next message
audiophile is currently offline  audiophile
i would like to know how to use a multimeter to check if i have a good ground and check the rest of the system.
Re: how to use a multimeter when installing car audio system? [message #59826 is a reply to message #59801] Mon, 06 July 2009 00:42 Go to previous messageGo to next message
music is currently offline  music
on the multi meter take the black wire and attatch it to your cars ground wire for the cd deck. then take the red wire on the multi meter and touch the power wire. should jump really to 12v if u got good ground
Re: how to use a multimeter when installing car audio system? [message #59832 is a reply to message #59801] Mon, 06 July 2009 00:46 Go to previous message
euphonics is currently offline  euphonics
You can check the ground using this link...
http://www.the12volt.com/installbay/forum_posts.asp~TID~49445~PN~1
You can set your gain by using these links...
http://mobile.jlaudio.com/support_pages.php?page_id=143
http://www.thesuicidaleggroll.com/gain.htm
You can check the voltage at an amplifier by measuring across the power and ground cable. It should be around 13-14.4 volts at the amp when the car is running.
Good Luck!!!
Previous Topic: Can you Help? Audio amp wire routing.?
Next Topic: Welcome to Crescendo Systems!
Current Time: Thu Nov 05 08:03:30 CST 2026
