Home » Sponsored » Pi Speakers » How high does the pi 7 bass horn go?
How high does the pi 7 bass horn go? [message #53531] Wed, 13 May 2009 16:47 Go to next message
xcortes is currently offline  xcortes
More specifically the 18" version.
Thanks!
xavier
Re: How high does the pi 7 bass horn go? [message #53532 is a reply to message #53531] Wed, 13 May 2009 16:55 Go to previous messageGo to next message
It depends on the driver.
Re: How high does the pi 7 bass horn go? [message #53533 is a reply to message #53532] Wed, 13 May 2009 16:58 Go to previous messageGo to next message
2241H
Re: How high does the pi 7 bass horn go? [message #53535 is a reply to message #53533] Wed, 13 May 2009 18:44 Go to previous messageGo to next message
That driver will run higher than you probably need. How high do you want to crossover?
Re: How high does the pi 7 bass horn go? [message #53536 is a reply to message #53535] Wed, 13 May 2009 18:45 Go to previous messageGo to next message
500hz
Re: How high does the pi 7 bass horn go? [message #53537 is a reply to message #53536] Wed, 13 May 2009 19:35 Go to previous messageGo to next message
Yes, it will reach that high. The thing is, above a couple hundred Hertz, the walls start to act as reflectors. This makes a few blips in the response curve from self-interference with the boundaries. When you look at averaged response, you can run the woofer way up high but a high-resolution plot will show self-interference notches above 300Hz.
thanks (nt) [message #53538 is a reply to message #53537] Wed, 13 May 2009 22:14 Go to previous message
nt
Previous Topic: Active Theater 4 Bi-Amping
Next Topic: Any new horn flares to work with midhorn?
Current Time: Sat Oct 24 20:30:26 CDT 2026
