Home » Sponsored » Pi Speakers » Alterations to 7 Pi bass bin ?
Alterations to 7 Pi bass bin ? [message #53493] Mon, 04 May 2009 00:28 Go to next message
jimbop is currently offline  jimbop
Wayne, is it possible to change the dimensions of the 7 Pi bass bin to make it shorter and wider, while retaining the proper volume?
Jim D.
Re: Alterations to 7 Pi bass bin ? [message #53496 is a reply to message #53493] Mon, 04 May 2009 12:10 Go to previous message
You can as long as you don't go crazy. The vertical distance helps provide distributed sound sources in the upper modal region and reduces floor bounce. It's not that it needs to be an exact distance, but you don't want it to be too little or you'll not get the smoothing desired.
Previous Topic: Where is Bill Epstein ???
Next Topic: Beginner questions
Current Time: Sat Oct 24 20:29:46 CDT 2026
