Home » Sponsored » Pi Speakers » Pi7 port plans
Pi7 port plans [message #53312] Tue, 17 March 2009 23:57 Go to next message
Wayne, am I misunderstanding the Pi7 baffle cut-out port details included with the Pi7 plans you kindly emailed recently, or is it a different design to the one used by PaulW, as pictured above?
Re: Pi7 port plans [message #53313 is a reply to message #53312] Wed, 18 March 2009 11:57 Go to previous messageGo to next message
It is different. I used to use a port like pictured in your post, one that I called a "periscope" layout. I changed the port to be bent in an "L" shape, formed with one side piece and two top pieces. It's just easier to make, in my opinion. Both tune the box to the same 37Hz Helmholtz frequency.
Re: Pi7 port plans [message #53314 is a reply to message #53313] Wed, 18 March 2009 23:25 Go to previous message
Cheers! Best to check before breaking out the Black and Decker.
Previous Topic: mid horn flat pack
Next Topic: Waveguides verses Horns
Current Time: Sat Sep 26 01:56:10 CDT 2026
