Home » Sponsored » Pi Speakers » OEM Eminence driver C15B95 question
OEM Eminence driver C15B95 question [message #52829] Tue, 28 October 2008 14:45 Go to next message
themilford is currently offline  themilford
I came across this driver in my stocks... not sure where I got it but can you guys suggest a enclosure size and port tuning for optimum performance... Eminence sent me these T/S parameters:
RE OHMS 5.73
LE MH 1.65
QM 5.12
QE .390
QT .360
XMAX MM 6.20
BL TM 18.54
EFF % 3.10
FS HZ 41.00
MMS GMS 91.38
CMS mm/N .1649
RMS NS/M 4.5956
VAS LTRS 183.28
SD SCM 889.59
EBP 104.4
SPL dB 96.9
thanks!
Re: OEM Eminence driver C15B95 question [message #52830 is a reply to message #52829] Tue, 28 October 2008 15:00 Go to previous messageGo to next message
Forgot to mention: 3" vc, 95oz. Magnet. Not sure the RMS wattage. It's a cast frame, fully ribbed cone ala Basslite C2515 and a big felt dustcap.
Re: OEM Eminence driver C15B95 question [message #52831 is a reply to message #52830] Tue, 28 October 2008 15:38 Go to previous message
From the T/S specs, it looks like it's similar to many other prosound woofers. It trades a bit of extension for efficiency, so you might want subs with it. That said, it's pretty much a drop-in replacement for any speaker that uses the Eminence Omega 15 or JBL 2205, 2225 or 2226.
Previous Topic: pi 7 cornerhorn
Next Topic: 2-Pi towers port freq???
Current Time: Sat Oct 24 22:40:23 CDT 2026
