Home » Sponsored » Pi Speakers » Headphones with smooth freq.
Headphones with smooth freq. [message #52262] Sun, 29 June 2008 22:27 Go to next message
Does Wayne P. Know of any headphones that have a smooth freq. response,
that dont cost a lot??? thanks
Re: Headphones with smooth freq. [message #52269 is a reply to message #52262] Mon, 30 June 2008 22:41 Go to previous messageGo to next message
Define "a lot."
Re: Headphones with smooth freq. [message #52270 is a reply to message #52262] Tue, 01 July 2008 00:19 Go to previous messageGo to next message
Might I suggest you post the same question over at Headwize and Head-Fi. Those forums are dedicated headphone enthusiasts.
The lower end Grados are great for rock music and can be had for less than $150. You can even step into used better models pretty reasonably as well. Both the forums above, especially Head-Fi, have a great for sale section.
Sennheisers are really good for jazz, classical, and so forth IMO.
I personally have a set of AKG-240S cans that I like and run about $100.
Re: Headphones with smooth freq. [message #52274 is a reply to message #52269] Tue, 01 July 2008 22:10 Go to previous messageGo to next message
$100.00 to 150.00 thanks
Re: Headphones with smooth freq. [message #52276 is a reply to message #52274] Wed, 02 July 2008 11:49 Go to previous message
I bought my wife a pair of Sennheiser HD280's and like those pretty well. My initial impression was that the bass was a little
underwhelming, but it does go plenty deep. This was based on listening to an iPod. Since then, they seem really nice, just a
little different than the other cheap Koss I use. The cusions are a littel stiff, though. Another option are Sony MDR 7506's. Similar
design, same price ($99), supposedly good reputation. Haven't tried them.
Chris
Previous Topic: Crossover update and a monster recording
Next Topic: 4 Pi crossover for 800hz request
Current Time: Fri Sep 25 09:53:18 CDT 2026
