Home » Sponsored » Pi Speakers » Omega 15-pro
Omega 15-pro [message #52234] Sat, 21 June 2008 20:28 Go to next message
I noticed that the specs have changed on the Omega 15 over the years ,
does the new one have more bass since the Fs is lower???
Eminence specifications [message #52237 is a reply to message #52234] Sun, 22 June 2008 21:30 Go to previous messageGo to next message
Eminence seems to change their published specs from time to time. We used to monitor their spec sheets and make announcements when selected drivers changed. But they tend to keep their changes within a range that works pretty much the same in a given box.
People within Eminence have said the drivers haven't changed in the past few years, that it's the way they've tested them that's changed. That is definitely possible, since electro-mechanical parameters shift depending on power level. I'm not just talking about increases in Re at high power either, there is pretty significant movement in electro-mechanical parameters as drive level changed, even at low to medium power levels.
Fortunately, π Speakers are slightly overdamped by design, and that makes them fairly tolerant of T/S shifts. Because of this, small electro-mechanical changes due to manufacturing tolerance, power levels or environmental conditions are a non-issue. The DI-matched two-ways are sensitive to cone and cap material and shape though, so if they change those then performance may be affected.
Re: Eminence specifications [message #52239 is a reply to message #52237] Tue, 24 June 2008 01:21 Go to previous message
Thanks for the reply..God Bless
Previous Topic: Hey Wayne, long time no talk!
Next Topic: New to forum, building 2Pi towers
Current Time: Sat Oct 24 22:39:45 CDT 2026
