Home » Sponsored » Pi Speakers » kappa pro
kappa pro [message #52111] Tue, 13 May 2008 20:55 Go to next message
solomty is currently offline  solomty
Hy .Wayne Could tell me where can use a 15 Kappa pro in your designs .Thanks
Re: kappa pro [message #52112 is a reply to message #52111] Tue, 13 May 2008 22:49 Go to previous messageGo to next message
Hey ! I 2nd that question ?
Re: kappa pro [message #52113 is a reply to message #52112] Wed, 14 May 2008 00:40 Go to previous messageGo to next message
Sorry, no. I haven't done a design around that woofer. It may work, but without some measurements, I can't say for sure. The cabinets and crossovers are designed with specific drivers in mind. Models with optional drivers have crossover changes that are specific to the drivers used. So I can't recommend alternative drivers other than those shown in the options lists for each model.
Re: kappa pro [message #52115 is a reply to message #52113] Wed, 14 May 2008 02:09 Go to previous messageGo to next message
Thanks for the info Wayne. Sure would like your opinion on these kappa pros anything would be appreciated.
Re: kappa pro [message #52121 is a reply to message #52115] Wed, 14 May 2008 18:28 Go to previous message
dB is currently offline  dB
The KAPPA PRO 12" has an fs=37Hz, lower 10Hz from the 15", and higher Xmax of 4.8mm vs. 3.2mm for the 15" what's good also. It is also possible to use the software PiAlign (by Wayne) that may give very good designs for DIY and is not difficult to learn.
Previous Topic: Gov. Stimulis rebate works!
Next Topic: 4 Pi-pro system reference in Manley Stingray amp review
Current Time: Sat Oct 24 22:40:39 CDT 2026
