Home » Sponsored » Pi Speakers » Gov. Stimulis rebate works!
Gov. Stimulis rebate works! [message #52105] Fri, 09 May 2008 17:31 Go to next message
DICK is currently offline  DICK
For me at least. With it I was able to procure a pair of jbl 2226h woofers whose cost used every bit of the stimulis incentive. And then some. My small bit in the larger scheme of things. Anyways now I'm gonna start building my 2nd pi, a bass bin 4pi with the mid-horn and wood horn (I hope) on top. I know alot of people inquired about using the mid-horn with the 4pi. Has any one converted their existing 4pi with the mid-horn or built the hybrid 4pi that I'm attempting? I'm curious to know your results. Thanks.
Rick
Re: Gov. Stimulis rebate works! [message #52114 is a reply to message #52105] Wed, 14 May 2008 01:37 Go to previous messageGo to next message
I don't have any results, but I'm going to do the exact same setup. I have the mid horns built and will use the standard tweeter/horn for now. I just need to find the time to build the bass bins. I hope some others chime in.....C
Re: Gov. Stimulis rebate works! [message #52118 is a reply to message #52114] Wed, 14 May 2008 12:45 Go to previous message
I have both fours and sevens, both with JBL woofers. The hybrid 4/7 is basically the same thing as a seven π if it's in the corner, angled in 45°. In most cases, that isn't done because the whole reason a person opts for the 4/7 hybrid is they don't have the corners. Then position becomes much more of a variable. The more radiating angle you have to cover, the more compromised the bass and lower mids are. So corners is best, back against a wall is second best. I wouldn't pull them out into open space.
Previous Topic: Pi Theater Four and B&C compression drivers
Next Topic: kappa pro
Current Time: Sat Oct 24 22:39:12 CDT 2026
