Home » Sponsored » Pi Speakers » Pi 12 v2
Pi 12 v2 [message #51776] Mon, 28 January 2008 03:26 Go to next message
Roland Gama is currently offline  Roland Gama
Hello Wayne,
Started work on the above mentioned project. Began by drawing the motor chamber layout on the side panels.
However I have trouble with two points on the plans which are not shown. The points where 1) MC9 and MC10 meet and 2) MC12 and MC11 meet.Could you clarify them for me.
Or should I build the motor chamber first and let it fall to place?
Awaiting help: Roland.
Re: Pi 12 v2 [message #51778 is a reply to message #51776] Mon, 28 January 2008 09:27 Go to previous message
The way we build them is to make the motor chamber first and then mount the completed assembly to the cabinet sides. The drawings were done with that in mind, and I don't think additional measurements are required. However, I can ask the draftsman to add those dimensions if you think it would be helpful.
You'll notice that in both of those, the sides of the motor chambers are formed by the sides of the horn cabinet. One of the early production model changes was to build the motor chamber complete with side pieces and attach the completed assembly to the horn cabinet. It comes together better that way and makes alignment of everything easier.
Previous Topic: 12Piv2 plans
Next Topic: SEP compatibility
Current Time: Sat Oct 24 23:02:50 CDT 2026
