Home » Sponsored » Pi Speakers » Theater 4 and 7 plans
Theater 4 and 7 plans [message #51593] Mon, 10 December 2007 04:26 Go to next message
zena49 is currently offline  zena49
I'm looking to build a pair of high efficiency speakers from a kit for use with a single-ended amp with the 300B. Could I have the plans for the Theater 4 Bass Reflex speakers and the Theater 7 corner horns, so that I can figure out a total cost, and how complex they are to build?
A corner of the room has a prominent slate slab and I must place the Theater 7 at 2" from this corner. Is this a big problem?
I have a 3m x 7m room and i must put the speakers along the short wall; has anyone a suggestion of which set of speakers would be the most appropriate to my room (i think the Theater 4).
Regards from Italy Angelo
You've got mail! [message #51597 is a reply to message #51593] Mon, 10 December 2007 10:44 Go to previous messageGo to next message
I'd prefer the cornerhorns, and while the Theater sevens sound nice, they may be a bit big for you. If so, you might consider the Theater six π instead. It's a great sounding speaker. I'll send plans for the Theater Series three π and six π in addition to the four and seven, just in case.
The seven π cornerhorns present a very flat impedance curve, so I expect your amplifier will have no trouble driving them. The Theater three π is an excellent speaker, but impedance peaks in the bass range are a little higher.
I prefer to place cornerhorns at opposite ends of a short wall in rectangular rooms. I prefer this on rooms with 5/7 ratio or so. You're is a little bit more narrow than that, but this only makes it even more important that you place them on the short wall. What this does, is makes the best listening area in the first 3m back from the wall where both speakers are.
Re: Theater 4 and 7 plans [message #51603 is a reply to message #51593] Wed, 12 December 2007 04:47 Go to previous message
Thanks for all
Previous Topic: Specs
Next Topic: Pi mid horn vs. Klipsch Lascala
Current Time: Sat Oct 24 22:49:56 CDT 2026
