Home » Sponsored » Pi Speakers » Bigger is ...
Bigger is ... [message #51537] Sat, 10 November 2007 00:00 Go to next message
Zene Gillette is currently offline  Zene Gillette
Hi ... Are there any true 12" high efficiency midrange speakers for use in a waveguide? Bass will be one of the 7PI's.
Zene
JBL 2012 and 2020, Eminence Delta 10A and Delta 12A [message #51538 is a reply to message #51537] Sat, 10 November 2007 09:35 Go to previous messageGo to next message
Check out the JBL 2012 (10") and JBL 2020 (12"). Also check out the Eminence Delta 10A (10") and Delta 12A (12").
Each of these are excellent drivers that work very well in a midhorn.
Re: JBL 2012 and 2020, Eminence Delta 10A and Delta 12A [message #51539 is a reply to message #51538] Sat, 10 November 2007 14:12 Go to previous messageGo to next message
Thanks, Wayne ... graph looks terrible on both Eminences from 1500hz up.
Am I missing something? You have heard, I have never. Horns may help, but WG's probably not.
Zene
Re: JBL 2012 and 2020, Eminence Delta 10A and Delta 12A [message #51541 is a reply to message #51539] Sun, 11 November 2007 08:34 Go to previous messageGo to next message
What you're seeing are breakup modes. They make the curve rise like that, but they actually measure pretty consistently. It's not a choppy curve, it's a steady rise. That helps midhorns with these drivers have useable response above 1kHz. Without that response curve shape, you wouldn't have much output up high.
Re: JBL 2012 and 2020, Eminence Delta 10A and Delta 12A [message #51545 is a reply to message #51541] Sun, 11 November 2007 18:10 Go to previous messageGo to next message
Wayne ... Quick thanks and follow up.
How high can I take each of the four and still maintain low distortion?
They will be used in WG's so top end won't be as restricted compared to horns.
Zene
Re: JBL 2012 and 2020, Eminence Delta 10A and Delta 12A [message #51547 is a reply to message #51545] Sun, 11 November 2007 20:15 Go to previous messageGo to next message
You'll find that the horn will naturally limit upper response for you, unless you add a phase plug. The acoustic low-pass filter formed by the horn makes a nice natural limiter of high frequency breakup.
Re: JBL 2012 and 2020, Eminence Delta 10A and Delta 12A [message #51548 is a reply to message #51547] Sun, 11 November 2007 20:21 Go to previous message
Wayne ...Sounds good. I have tweeters available to go almost anywhere. Got it, build and listen. Appreciate help as usual.
Zene
Previous Topic: Pi kit info
Next Topic: jbl 2447
Current Time: Sat Oct 24 23:45:42 CDT 2026
