Home » Sponsored » Pi Speakers » Studio Two construction pics?
Studio Two construction pics? [message #51523] Tue, 30 October 2007 15:11 Go to next message
Williston is currently offline  Williston
Hi,
Can anyone direct me to a good set of Studio Two construction photos? Searching the archive brings up a few links but they're mostly dead. Trying to figure out if I can build these or if I have to hire someone.
Thanks in advance,
Peter
Re: Studio Two construction pics? [message #51524 is a reply to message #51523] Tue, 30 October 2007 19:08 Go to previous messageGo to next message
The following pix are for avery similar 2 way design:
Sure you can. Just a box with a couple of holes.:-)
Re: Addendum and oops [message #51526 is a reply to message #51523] Tue, 30 October 2007 20:45 Go to previous messageGo to next message
Don't know how that double post happened.
Just wanted to add a few things:
Screws or nails are a viable alternative to clamps, plywood is less messy and lighter than MDF, White or yellow carpenters glue is best, and not to obsess over methods and materials; some Pi is better than no Pi!
Re: Addendum and oops [message #51528 is a reply to message #51526] Tue, 30 October 2007 22:22 Go to previous messageGo to next message
Thanks for your help, Bill. I deleted that accidental second post.
Re: Addendum and oops [message #51530 is a reply to message #51526] Wed, 31 October 2007 11:46 Go to previous message
Thanks Bill, that helps. Ordered the kit parts this morning.
Peter
Previous Topic: Replacement For Fiberglass in 2Pi
Next Topic: Pictures
Current Time: Sat Oct 24 23:44:51 CDT 2026
