Home » Sponsored » Pi Speakers » Near field monitors...
Near field monitors... [message #51420] Wed, 26 September 2007 16:13 Go to next message
Tim Barnes is currently offline  Tim Barnes
Hi Wayne:
Do you have any plans to offer designs for more compact applications? I'm remodelling my home office in such a way that my desk is in a 7' wide nook with a window in front. I want to set up a pair of speakers in the corners above the desk (so only about 4' from my head) for listening to music while I work. Amp is a gainclone fed from a Presonus firewire box.
I'd like something fairly compact, although they could be long and thin, and possibly a triangular cabinet to fit in the corner.
Any ideas?
Re: Near field monitors... [message #51421 is a reply to message #51420] Thu, 27 September 2007 09:27 Go to previous messageGo to next message
I really don't have anything smaller than the one π and two π models. The thing is, high-efficiency designs can't be small without sacrificing bass response. So the one π is about as small as I can go. You might try a pair of those. You could also do a version like Fred Thompson did, which was a tower cabinet using the Alpha 8. That way he was able to make it a little larger and still keep a small footprint. Don't go bigger than two or three cubic feet though, and tune it to be overdamped if it will be placed in corners.
Re: Near field monitors... [message #51422 is a reply to message #51421] Thu, 27 September 2007 11:43 Go to previous message
Thanks - high efficiency is not a priority for this setup, although good dynamics are. I find that my current system (Gainclone with tweaked Radio Shack Minimus 7s) is turned down almost to the lowest volume setting most of the time.
I'll have a look at the Alpha 8 and a tall thin cabinet.
tim
Previous Topic: 2/3s of 7Pi's done
Next Topic: Theater Sevens too small large for our place..dang.
Current Time: Sat Oct 24 23:40:13 CDT 2026
