Home » Sponsored » Pi Speakers » pi 8 question
pi 8 question [message #51274] Tue, 24 July 2007 09:56 Go to next message
cheyoung is currently offline  cheyoung
May I know what is the cut off frequency for the pi 8 mid horn?
cheyoung
Re: pi 8 question [message #51275 is a reply to message #51274] Tue, 24 July 2007 11:49 Go to previous messageGo to next message
There is a lot of good information about the midhorn in the post below, including response charts with and without the crossover and tweeter.
Re: pi 8 question [message #51276 is a reply to message #51275] Tue, 24 July 2007 11:57 Go to previous messageGo to next message
hi wayne,
if i would to make it round then should i based on 150hz free space ?
cheyoung
Re: pi 8 question [message #51278 is a reply to message #51276] Tue, 24 July 2007 16:11 Go to previous message
It depends where you will be using the horn. If you plan to use it out in the open but standing on the ground, model it in half space. It will be close enough to the ground to get some loading at the lowest frequencies. Changes like this are pretty substantial though, so I wouldn't expect it to act the same.
Previous Topic: Tweeter Attenuation on Pi 8s
Next Topic: 7 Pi plans please
Current Time: Sat Oct 24 23:34:22 CDT 2026
