Home » Sponsored » Pi Speakers » 8Pi
8Pi [message #51270] Mon, 23 July 2007 08:46 Go to next message
gdavis is currently offline  gdavis
I was wondering if i could change the 8Pi Dim's a bit.the overall dim's would be 16.5 Wx56.25Hx13.5D i would rotate the midhorn 90deg
Re: 8Pi [message #51272 is a reply to message #51270] Mon, 23 July 2007 13:23 Go to previous message
No, that won't work. The orientation of the midhorn should stay as it is. If you rotate it 90°, the pattern will be wrong. The loading will be wrong and energy would be wasted on ceiling and floor reflections. If you need a narrower box, forgo this midhorn entirely and use something else.
Previous Topic: Pi8 PLANS
Next Topic: Tweeter Attenuation on Pi 8s
Current Time: Sat Oct 24 23:34:43 CDT 2026
