Home » Sponsored » Pi Speakers » Aurum Cantus G2Si
Aurum Cantus G2Si [message #50915] Thu, 29 March 2007 08:53 Go to next message
jimbop is currently offline  jimbop
Wayne, would the Aurum Cantus G2Si work as a supertweeter with the 4 Pi speakers? Parts Express has them on sale for $60.
http://www.e-speakers.com/catalog/aurum_cantus_g2si_4284956.htm
Jim D.
Re: Aurum Cantus G2Si [message #50916 is a reply to message #50915] Thu, 29 March 2007 11:40 Go to previous messageGo to next message
Yes, it should work. If you're planning it as an add-on, with no crossover changes, then crossover high, like above 8kHz.
Re: Aurum Cantus G2Si [message #50917 is a reply to message #50916] Thu, 29 March 2007 20:42 Go to previous messageGo to next message
Which, of course, brings up the next question:
What do I need to crossover around 8kHz)? (I have no experience in this area)
Jim
Re: Aurum Cantus G2Si [message #50918 is a reply to message #50915] Fri, 30 March 2007 07:21 Go to previous messageGo to next message
I did that with my Theater 3Pi's using the Fountek equivalent of the G2Si. The ribbon added a clearly audible element of "air" that I don't hear with just the horn tweeter. It's especially audible with cymbals, etc. I used a second order crossover with a 1.0uF Audiocap Theta and a Dayton 0.2mH 20ga air core shunt inductor. But be warned, that added "air" makes the speaker sound more like all those expensive "high end" speakers (Wilsons, etc.) that WOW you when the salesperson plays a reference quality SACD on a $10K player, but can sound harsh and fatiguing with most CD's that aren't recorded especially well.
Re: Aurum Cantus G2Si [message #50920 is a reply to message #50917] Fri, 30 March 2007 19:27 Go to previous messageGo to next message
dB is currently offline  dB
A second order 8KHz xover (w/110+ phase on the driver).
C = 1.5uF (series)
L = 0.47mH (paral.)
LPad (without it, it will be to loud)
R1= 1.5 Ohms (series) NI
R2= 20 Ohms (shunt) NI
or a little less damping (about +1dB)
R1= 1.0/0.6/ Ohms NI
R2= 20 Ohms NI
Note: This is assuming that the driver output is linear and sensitivity is the same between speaker drivers.
This is not final. Wayne?
Good luck!
Re: Aurum Cantus G2Si [message #50922 is a reply to message #50920] Sat, 31 March 2007 10:36 Go to previous message
Sounds like a good plan. I'd give it a go.
Previous Topic: One Pi- Laurels and Nits
Next Topic: power graph in BoxPlot
Current Time: Sat Oct 24 23:52:51 CDT 2026
