Home » Sponsored » Pi Speakers » dedicated sub
dedicated sub [message #50773] Wed, 07 March 2007 07:02 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy Wayne . a few post below you say that the Alpha 10 can work as a dedicated subwoofer .taking this way the Alpha 10 could have better bass response that the 35 hz tuned tower 2 box .Does you have plans for a alone sub Alpha 10 box that could share .thanks
Re: dedicated sub [message #50775 is a reply to message #50773] Wed, 07 March 2007 08:49 Go to previous messageGo to next message
The Alpha 10 works well as an inexpensive sub in cabinets around 5ft3 to 7ft3 tuned to 35Hz. It's a little limited in excursion and power handling, so you might also look at the LAB12, which will go lower in a smaller box. Tune it for 22Hz in a 3.5ft3 box.
Re: dedicated sub [message #50782 is a reply to message #50775] Wed, 07 March 2007 15:01 Go to previous messageGo to next message
Hy .. So I must understand that the two Pi tower is a sub per se .thanks
Re: dedicated sub [message #50784 is a reply to message #50782] Wed, 07 March 2007 15:17 Go to previous message
The box size and tuning of a two π tower is right, but I think for a sub, I might shape it differently. I'd also limit frequencies to 100Hz or so, and naturally, not bother to install a tweeter. But the box tuning is right for use as a sub.
Previous Topic: Is the Thermionic Studio Eight horn a corner horn?...nt
Next Topic: TAD 2 way.. need crossover.
Current Time: Sat Oct 24 23:52:08 CDT 2026
