Home » Sponsored » Pi Speakers » PiAlign.Doc Changed since 2001?
PiAlign.Doc Changed since 2001? [message #50713] Sun, 18 February 2007 13:42 Go to next message
ChrisL is currently offline  ChrisL
Hi Wayne,
I was reading your Pi Align doc and I realized a had two copies. One is at least a few years old. Did you delete one of the speaker designs in the back of the document? The horn that's not a corner horn? If so, why? It looks like a cool way to make a bass horn touring cabinet or a home speaker.
Thanks for sharing your great work.
Regards,
Chris L.
Re: PiAlign.Doc Changed since 2001? [message #50714 is a reply to message #50713] Mon, 19 February 2007 09:40 Go to previous messageGo to next message
Yes, I removed the 1970's ten π picture from the back, which was a horn with a spiral style fold. I'm still making basshorns that way, but the old ten π is now obsolete. Check out the 12π basshorn instead.
Re: PiAlign.Doc Changed since 2001? [message #50716 is a reply to message #50714] Mon, 19 February 2007 12:02 Go to previous messageGo to next message
spkrman57
Wayne,
Is that due to the very large size of the 10 Pi horn?
Regards, Ron
Re: PiAlign.Doc Changed since 2001? [message #50717 is a reply to message #50716] Mon, 19 February 2007 14:39 Go to previous message
That's one reason. The other is that the 9π/12π combination supercedes it. The old ten π was a folded horn that used a 2205, 2225 or 2226 driver. It had had just one fold, and its panels acted as reflectors for higher frequencies. So it could be used to relatively high frequency. But the midbass horn in the 9π also uses the 2226, and it is a straight horn. Naturally, this is a cleaner arrangement.
Previous Topic: 2 Pi tower making music!!!
Next Topic: Another vote for a Pi One Tower w/ dual woofer
Current Time: Sun Oct 25 00:33:58 CDT 2026
