Home » Sponsored » Pi Speakers » Theater 4's and DIY Tubes
Theater 4's and DIY Tubes [message #50461] Wed, 03 January 2007 07:08 Go to next message
Aaron is currently offline  Aaron
What DIY tube amps would you recommend for Theater 4's?
Re: Theater 4's and DIY Tubes [message #50463 is a reply to message #50461] Wed, 03 January 2007 09:24 Go to previous messageGo to next message
There are plenty of tube amps at various price points that sound great with Theater four π loudspeakers. As for kits, you might look at those from DIYHifiSupply, Welborne, Bottlehead, Transcendent, Audio Note and Heart/Stoetkit. I particularly like the Stoetkit Jr. for a low-cost kit. It's a 9 watt ultra-linear amp that looks and sounds great.
Re: Theater 4's and DIY Tubes [message #50464 is a reply to message #50463] Fri, 05 January 2007 05:00 Go to previous messageGo to next message
Wayne,
What do you think of the Bottlehead Foreplay and Paramount 300B combination, for the 4 Pi's?
Re: Theater 4's and DIY Tubes [message #50465 is a reply to message #50464] Fri, 05 January 2007 10:33 Go to previous message
It is a fine combination. I used the Paramours for a while, and found them to be fairly insensitive to load impedance, which is something that tends to be a problem with many SET amps. The parafeed output seems to swamp back-EMF effects from the woofer. Because of this, even speakers with fairly high impedance peaks sound good, and don't have corresponding response dips.
Previous Topic: MONITOR SERIES
Next Topic: Looking for some speaker magic in the UK.
Current Time: Sun Oct 25 00:33:01 CDT 2026
