Home » Sponsored » Pi Speakers » TEASER
TEASER [message #44342] Fri, 09 April 2004 00:53 Go to next message
Here
Re: TEASER [message #44343 is a reply to message #44342] Fri, 09 April 2004 04:53 Go to previous messageGo to next message
andreas paulsen is currently offline  andreas paulsen
Arrhh Nein...
Wayne you are nearly forcing me to start saw-dusting a pair of cornerhorns with 2245 and with the midrange horn and some kind of tweeter horn on top.
How low does i go ?
Good work.
Cheers
andreas
Re: TEASER [message #44344 is a reply to message #44343] Fri, 09 April 2004 05:09 Go to previous messageGo to next message
150Hz in a corner, 250Hz if not.
Re: TEASER [message #44345 is a reply to message #44344] Fri, 09 April 2004 05:25 Go to previous messageGo to next message
Sounds good, it could then even connect to a corner loaded lab horn if anynone wishes.
However an all-horn version of the audiophile pi-seven corner horn would be an absolute killer i'm sure --- and loud too !
cheers
andreas
Re: TEASER [message #44346 is a reply to message #44342] Fri, 09 April 2004 06:36 Go to previous messageGo to next message
Duncan McBride is currently offline  Duncan McBride
This looks really cool. What are the external dimensions?
Re: TEASER [message #44348 is a reply to message #44346] Fri, 09 April 2004 15:35 Go to previous messageGo to next message
The midhorn is 24" wide, 12" tall and 20" deep (including the driver). I'm still working on the eight π, but I expect it to be about 3 feet tall and two feet wide.
Re: TEASER [message #44349 is a reply to message #44345] Fri, 09 April 2004 15:43 Go to previous messageGo to next message
Yeah, that's what this midhorn was really for. The π cornerhorns were designed as a three-way, as was the ten π folded horn. In both cases, the woofer was expected to go to somewhere in the 300Hz to 600Hz range and then crossover to a midrange. I found that they ban be used much higher, and they sound great and look great too. Makes the system less complex. But there are benefits in having a dedicated midrange, and this one works well and looks good. It's a great mdeium-size vocal range horn.
Re: TEASER [message #44351 is a reply to message #44344] Fri, 09 April 2004 18:01 Go to previous messageGo to next message
Do you have the numbers reversed, and it not, why?
Chris
Re: TEASER [message #44352 is a reply to message #44351] Fri, 09 April 2004 18:09 Go to previous messageGo to next message
Putting the horn in a corner room position is 1/8th space and will allow the horn to be used at a lower frequency. Free standing or only backed by a wall and floor the horn will rely on the mouth size more. generally speaking
Bill
Re: TEASER [message #44353 is a reply to message #44351] Fri, 09 April 2004 18:10 Go to previous messageGo to previous message
Boundary loading tends to make a horn act like it's larger.
Previous Topic: Integration of mid and sub into theater 4's
Next Topic: Source Impedance
Current Time: Thu Nov 05 23:20:55 CST 2026
