Home » Sponsored » Pi Speakers » Wayne - Theater 4 Pi question
Wayne - Theater 4 Pi question [message #37276] Fri, 12 July 2002 12:07 Go to next message
Neo is currently offline  Neo
My Theater 4 Pi's seem to need more lower mid-range and bass when compared to my Sea's 5.5" monitors in an MTM arrangement
(BESL Series 5's http://www.bamberglab.com/series5.htm powered of course by a SS Threshold amp and preamp). I'm using the correct Eminance crossover and Eminence drivers with the extra components across the woofer and tweeter.
I'm using the 6db antenuation values for the tweeeter.
I'm at work or I'd be more specific.
Some changes I did make...
1- I increased the cabinet depth by 1" to allow for extra internal
reinforcement.
2- I installed 2"x4" 'belts' above and below the woofer for cabinet reinforcement, and I put a 2"x4" reinforcement in the middle of the top and bottom panels.
3- I'm using the Partsexpress Acoustic 1.5" foam (instead of 2" fiberglass) on three sides. I added more foam and some fiberglass - speakers got more defined and clear I think.
Your thoughts/suggestions please ...
Thanks
Tom
Re: Wayne - Theater 4 Pi question [message #37278 is a reply to message #37276] Fri, 12 July 2002 14:46 Go to previous messageGo to next message
Overdamping the inside of your enclosure could partially be the problem with the lack of lower midbass and bass output.
Lining your enclosure walls with damping material and stuffing the box with polyfill will only hurt the response of a ported box woofer. You really only need it for damping high frequency output and cleaning up the midrange/upper midbass a bit. Unfortunately, you might have to strike a compromise between these two.
JMO.
Adam
Theater 4 Pi answer [message #37279 is a reply to message #37276] Fri, 12 July 2002 14:47 Go to previous messageGo to next message
You need more attenuation for the compression horn. Do you have plans for the Theater Series four π Speaker? Do you want a copy of the plans? I recommend the π 1K6a010dB crossover, which attenuates the tweeter almost twice as much.
Re: Theater 4 Pi answer [message #37283 is a reply to message #37279] Sat, 13 July 2002 06:15 Go to previous messageGo to next message
Thanks for the input Wayne...
You emailed the plans for the theater 4 Pi's to me awhile ago. The dimentions where 2'x 3'x 18". I made them 2' x 3' x 19". This makes them about a .5 cu ft more than specs. Will this hurt ?
I used PartsExpress pxb2-1k6 part#290-634 cross overs with added elements R1 = 12 ohm, R2 = 30 ohm and C1 = .47uf for the tweeter. And C5 = 20 uf and R3 = 8 ohms for the woofer.
Did I go wrong somewhere ?
Are you still making crossovers for Pi 4's. Maybe it would be easier for me to just buy yours. I love the Pi's but I miss the mid-range...
Thanks again for your help.
Tom
P.S. My old moniker was tottman2. It is the email name my company invented based on my first and last name. Not very interesting. I love the movie Matrix, so I thought I'd borrow the stars name.
Re: Theater 4 Pi answer [message #37287 is a reply to message #37283] Sat, 13 July 2002 13:02 Go to previous messageGo to next message
The correct values for both R1 and R2 are 16 ohms. You can buy the completed crossovers directly from me if you like. π crossovers are $99.00 each. But I think if you'll just get some 16 ohm resistors, you'll be fine. You might be interested in the post called, "Compensation networks - Photos."
Thanks Wayne... [message #37294 is a reply to message #37287] Sun, 14 July 2002 12:17 Go to previous messageGo to next message
And thanks for the Matrix links etc...
I'm ordering the resistors I need right now.
After reading the links, I think I'll try my big SS amp on the Pi's, just see to see them glow !
Tom
Can you send me some Pi symbols for my speakers [message #37295 is a reply to message #37294] Sun, 14 July 2002 12:20 Go to previous messageGo to next message
And let me pay for them... or at least the postage.
My address is:
Tom Ottman
53 Westview terrace
Berlin, Ct 06037
Thanks Wayne
I'll send some today. [message #37303 is a reply to message #37295] Sun, 14 July 2002 14:43 Go to previous messageGo to next message
Re: I'll send some today. [message #37317 is a reply to message #37303] Mon, 15 July 2002 14:00 Go to previous messageGo to next message
Erik Johansson is currently offline  Erik Johansson
I would love get some Pi symbols for our 2 Pi speakers (4 of them in total). How much are they? I might get an extra pair of symbols since I might build the Thermionic 3 Pi or 4 Pi some day. I plan on getting a pair of Alpha 12 or Alpha 15 drivers when I pick up the Alpha 10 drivers in Germany. Then weŽll see what happens. IŽm building a pair of ProAc Response 2.5 clones for my main system and the 2 Pi speakers for my little 2x14W 6V6GT PP tube amp.
/Erik
Re: I'll send some today. [message #37323 is a reply to message #37317] Mon, 15 July 2002 15:44 Go to previous messageGo to previous message
Write to me at Wayne@PiSpeakers.com
Previous Topic: Any pi lovers in Australia?
Next Topic: T/S on the JBL 115H woofer
Current Time: Fri Nov 13 09:10:43 CST 2026
