Home » Audio » Group Build » Filament Caps
Filament Caps [message #30812] Fri, 04 March 2005 06:47 Go to next message
Anyone; while I wait for the 10k caps to be delivered; why can't I use the original 4.7K filter caps again??
That's what I used [message #30813 is a reply to message #30812] Fri, 04 March 2005 08:03 Go to previous messageGo to next message
I used what was on the heater schematic, which was 4.7 mF (4700uF)and I believe 25V rating. See link below and remember the resistors were changed to 2 and 2 ohm......Colin
Re: That's what I used [message #30814 is a reply to message #30813] Fri, 04 March 2005 08:22 Go to previous messageGo to next message
Thanks Colin; I am somewhat upset now. Where did the 10k come from??? I am sitting here like a nitwit waiting for some caps I don't even need!
I have that schematic but somehow I got the impression it was changed.
Jeez.
That's what I used [message #30815 is a reply to message #30814] Fri, 04 March 2005 08:29 Go to previous messageGo to next message
4k7 uF is aceptable, so is 10k uF. I ran a bit on the iffy side with 10k uF @ 16 V. I hope yo guys can see the risk in that. L-C filter with ~18 vac will over-voltage them in a big way if no load is applied to the filter.
10k was just as easy for me to get as 4k7. You'll be fine w/either. I keep forgetting to limit your options, and act like a dictator.
Gilligan, dreaming, promises the crowd, "this, that, and the other thing..."
regards,
Douglas
Less ripple w/10k uF [message #30816 is a reply to message #30815] Fri, 04 March 2005 08:47 Go to previous messageGo to next message
Ran a PSU simulation using 4.7k vs. 10k uF in the RCRC heater. 10k gives a lot less ripple if used in the first position (the one closest to the diodes) A change in ripple was not even noticed if the value was increased in the second position (cap closest to load) From this, you might want to hold off and use the 10k's. It sure looks like you'll be better off.....Colin
Re: Less ripple w/10k uF [message #30817 is a reply to message #30816] Fri, 04 March 2005 09:06 Go to previous messageGo to next message
Dictator; thats good, I like that. I want to get going here, before you guys move on and I am just a faint echo in the distance "Hallooo?"
I may need to post photo's for help; is that too much, like hogging the action? Don't be afraid to tell me; I'm not sensitive.
Also it don't matter; as far as perfection; all will change eventually anyway;no?
Re: Less ripple w/10k uF [message #30818 is a reply to message #30817] Fri, 04 March 2005 10:21 Go to previous messageGo to next message
Hey-hey!!!,
I'll help if you post photo's or not. Until You're satisfied.
regards,
Douglas
Re: Less ripple w/10k uF [message #30819 is a reply to message #30818] Fri, 04 March 2005 11:15 Go to previous messageGo to next message
"I just can't seem to be satisfied!"; Muddy Waters.(M'Kinley Morganfield.)
Is cap size worth increasing in heater PS? [message #30820 is a reply to message #30815] Fri, 04 March 2005 13:18 Go to previous messageGo to next message
From a PSU simulation, it looks like ripple is really reduced by increasing the size of the capacitor that is closer to the diodes - not quite as much as the LCRC but still reduced. In your opinion would it be worth John replacing the first cap with the 2 10uF in parallel and using one of his 4.7uF in the second position. I'm thinking of adding a 10uF in parallel across the 4.7uF I already have installed, giving a total capacitance of 14.7uF.....Colin
Re: Is cap size worth increasing in heater PS? [message #30823 is a reply to message #30820] Fri, 04 March 2005 13:35 Go to previous messageGo to previous message
Say Colin; are you up and running yet?
Previous Topic: Mounting Coupling caps
Next Topic: More amp design considerations
Current Time: Wed Nov 25 00:22:11 CST 2026
