| Tung Oil - How to? [message #29436] |
Fri, 08 April 2005 12:30  |
Messages: 19071 Registered: January 2001
I made a little sign for GPAF and I'm wiping tung oil on it to finish it. So I want to hear from the experts if I'm doing it right.What I did was to ask Brad to give me a piece of scrap walnut from one of the midhorns, and I took it to a CNC shop to cut my logo into it. I put a sheet of adhesive plastic on it as a mask and had them cut through that so I could paint the letters silver. Then I peeled off the mask to expose the walnut, and I'm rubbing tung oil into it. I thought it might be a good practice for me, since the only time I ever used tung oil was for touch up. This time, I wanted to see what uyou guys do to finish something properly. It's like wiping on vegetable oil or something, almost like water. I just use a cloth and wipe the stuff on in a very thin coat. I watch the reflection at an angle to see when the coat is uniform, then I go away for a few minutes. Maybe ten or fifteen minutes later, I come back and do it again. The first coat darkened the grain a little, just like I had moistened it with water. But the grain absorbs it and makes it look like you haven't done anything except darken it a tad. It took probably 20 coats before I could even tell it was holding a finish. Now it's starting to get a little shiny, but it seems like it will take 100 coats like this. That's no problem, it's easy, I just wipe it on. It's no more difficult than wiping a counter with a sponge. I rub it in a little, but it isn't like polishing a car or anything, it's more like just wiping it on. Is that what I'm supposed to do? It looks good, but is this the way tung oil is generally used?
| My method [message #29439 is a reply to message #29437] |
Sat, 09 April 2005 10:33   |
wunhuanglo
Messages: 912 Registered: May 2009
Illuminati (2nd Degree) |
Not that it's superior to anybody's, but it's how I do it. Soak it down. Wait overnight. Using fine (000) steel wool, rub oil into the wood like Simonizing a car in the old days. Keep on rubbing till it shines.
| Re:Put de lime in de coconut............ [message #29440 is a reply to message #29437] |
Sat, 09 April 2005 13:16   |
Bill Martinelli
Messages: 677 Registered: May 2009
Illuminati (1st Degree) |
I like a combination of both these guys. Apply a heavy coat and wipe most of it off after 1o minutes. then when the surface gets tacky in another 15 or 30 minutes. I rub it down hard with a clean soft rag to burnish the shine. If you apply another coat before the preceding coat hardened, then you end up re-dissolving, so to speak, the coat you just put on and don’t get as much build up as if you wait 4 hours to overnight. A fan can help speed things along. After two coats I use either fine steel wool or 600-1500 paper and smooth of the surface again. You can keep doing this until you’re happy with the finish.
| Speaking of building boxes... [message #29446 is a reply to message #29445] |
Sun, 10 April 2005 17:32   |
wunhuanglo
Eventually I'm going to build a pair of 3 ft^3 sealed subs. I was contemplating that today, and how to build them stiff/dead. It occured to me that people always use sheet stock and then add braces. Some do the B&W thing and add a honeycomb of sorts to fill and stiffen from the interior. Has anybody considered emulating a "stress panel" - building a frame out of say 2X2s and then covering the outside/inside with something like 1/2" MDF. I guess the cavities could be filled with Great Stuff or similar (expanding foam). That would result in walls 2-1/4 inches thick - ought to be quite stiff, like a helicopter floor. The baffle would probably be solid, or at least it would be most convienient.
| Re:Put de lime in de coconut............ [message #29448 is a reply to message #29437] |
Mon, 11 April 2005 07:49   |
GarMan
Messages: 960 Registered: May 2009
I take the "amature" approach, meaning I have no delivery timelines to meet and I take advantage of the fact that I have all the time in the world. Like Epstein suggested, flood the surface for 20 minutes. Sometimes, for smaller pieces, I let it sit in a tray to soak. Wipe off any excess. Wait 2 days to dry. For the next 10 days to 2 weeks, wipe a very thin coat on every other day. Don't try to build a layer with it. This method is very time inefficent. But for someone like me who lack advance skill and knowledge, time is a great replacement. There are also different types of tung oil too. "Natural" takes longer to dry. Polymerized are faster drying and I find is better at building a coat (which I don't like to do). "High Lustre" tung oil from Lee Valley can build a lacquer-like finish, but is difficult to use straight out of the bottle. I like to use a blend of Lee Valley's High Lustre and "natural" tung oil as final coat. One part High Lustre with 4 parts "natural" gives me a soft sheen. Gar.
