Home » Audio » General » Yamaha M-50
Yamaha M-50 [message #26499] Sun, 21 May 2006 15:08 Go to next message
MWG is currently offline  MWG
I picked one up this weekend and repainted the cover as it was pretty dog eared. It's no museum piece but it sure sounds good to me. It's 125 WPC. I plugged a cd player directly into it and like the crispness the extra power adds.
I bought it to use with my Maggies after I fix the tweeter. I got the kit from a friend so now all I have to do is settle down and run the wire. I probably should install new caps. What is recommended for speakers crossover caps?
Re: Yamaha M-50 [message #26500 is a reply to message #26499] Sun, 21 May 2006 20:28 Go to previous messageGo to next message
I hear the North Creek Zen's are good.
M-50 correction [message #26501 is a reply to message #26500] Sun, 21 May 2006 22:38 Go to previous messageGo to next message
It's 150 WPC not 125 hence the 50 designation..........doh
Re: M-50 correction [message #26502 is a reply to message #26501] Mon, 22 May 2006 15:34 Go to previous messageGo to next message
What amp is that? Is that the Class A model?
Re: M-50 correction [message #26503 is a reply to message #26502] Mon, 22 May 2006 15:46 Go to previous messageGo to next message
What year model? I really liked Yamaha amps and receivers from around 1980.
Re: M-50 correction [message #26504 is a reply to message #26503] Mon, 22 May 2006 18:53 Go to previous messageGo to next message
Well maybe I'll get it right yet. This one is from 1982 and has 120 WPC. It also doesn't have any of the harshness normally associated with higher power SS amps. My Altecs with the 811 horns will quickly point out any stridency in an amp It has volume controls which allow direct connection to a high output source like a cd player.
Re: M-50 correction [message #26505 is a reply to message #26504] Mon, 22 May 2006 19:02 Go to previous messageGo to next message
I rememmber the B1/B2 series; any relation? I have a 840 with the silver face and oak case laying around here somewhere. Nice sounding amp.
I am considering having my Luxman M 120A re-done for the Altecs; what do you think?
Re: M-50 correction [message #26506 is a reply to message #26502] Mon, 22 May 2006 19:13 Go to previous messageGo to next message
I don't have a owners manual for it but I know that some of the M-series started in class A until you cranked them up and then they switched out of class A operation.
Re: M-50 correction [message #26507 is a reply to message #26505] Mon, 22 May 2006 20:21 Go to previous messageGo to next message
I've tried many receivers and several ss amps including the M-50, Kenwood 6004 and my MC-2505 with my Altecs. So far none of them come close to the wonderful sound I get with the MC-275 tube amp.
Altecs just sound better with tubes. It's what they were designed for originally. I listened to and loved mine since 1966 and only had the tube amp working for a year. I miss it and finally have a line on a local repair guy if I can ever get in touch with him.
As for the Luxman I think they are top notch amps so it should sound good with it. If I had never tried the tube amp I would still be happy with the 2505
Re: M-50 correction [message #26508 is a reply to message #26507] Tue, 23 May 2006 06:15 Go to previous messageGo to previous message
Say MWG; whats wrong with the 275?
Previous Topic: New DIY modded FM tuner reviews on TIC
Next Topic: Excellent Debunking Website
Current Time: Mon Sep 21 21:39:53 CDT 2026
