Home » Audio » Speaker » Did Martin King do something with those?
Did Martin King do something with those? [message #20926] Tue, 24 May 2005 14:55 Go to next message
nt
Re: Did Martin King do something with those? [message #20927 is a reply to message #20926] Tue, 24 May 2005 15:35 Go to previous messageGo to next message
Martin is currently offline  Martin
With what?
Re: Did Martin King do something with those? [message #20930 is a reply to message #20927] Wed, 25 May 2005 07:14 Go to previous messageGo to next message
Those particular Fostek Drivers. I think I remmeber they might have been one of your earlier choices. Did I see that on your site?
Re: Did Martin King do something with those? [message #20931 is a reply to message #20930] Wed, 25 May 2005 07:55 Go to previous messageGo to next message
Which model?
Re: Did Martin King do something with those? [message #20933 is a reply to message #20931] Wed, 25 May 2005 11:58 Go to previous messageGo to next message
F103a. Also how is the Lowther experiment going with you?
Re: Did Martin King do something with those? [message #20937 is a reply to message #20933] Wed, 25 May 2005 17:30 Go to previous messageGo to next message
I have ten Radio Shack 1197 (blue and black boxes each marked FE 103) that I have played with a little. I have not built any formal project with them.
I have a back loaded horn design for the Lowthers worked out. I upgraded my advanced MathCad worksheets to account for the real wall reflection and also front or rear firing mouth location. The paper design has a fairly flat SPL down to 40 Hz with an efficiency of 95+ dB, depending on Lowther driver, without any BSC circuit. I am working on the folding scheme now so that it fits in a reasonable enclosure.
Progress on the Lowther designs has slowed some as I look into upgrading my amp and preamp. My old reliable Adcom preamp is not doing well and I am long overdue for an upgrade anyway.
Martin
Re: Did Martin King do something with those? [message #20938 is a reply to message #20937] Wed, 25 May 2005 17:59 Go to previous messageGo to next message
I would still like to pay a visit in June If you will have me. I would really like to hear what you have with the Lowthers. Saying all that, what equipment do you have your eye on?
I am reading slowly your paper so as to have some understanding should I get to hear the QWLD's.
Re: Did Martin King do something with those? [message #20939 is a reply to message #20938] Wed, 25 May 2005 18:05 Go to previous messageGo to next message
Right now I am considering Bryston and Odyssey Audio. If I go Bryston, it would be most likely a BP-20 preamp and a 3BSST or 4BSST amp. If I go Odyssey, it would be a Tempest extreme preamp and a pair of Stratos monoblock extreme amps. I just need to get motivated to move towards a decision and place the order. Things have been busy at work and at home this month.
Martin
Re: Did Martin King do something with those? [message #20940 is a reply to message #20939] Wed, 25 May 2005 19:47 Go to previous messageGo to next message
Bryston is good stuff. I am curious why you need so much power though.
Re: Did Martin King do something with those? [message #20941 is a reply to message #20940] Thu, 26 May 2005 05:05 Go to previous messageGo to previous message
OK, lets say we start with a 200 watt amp (for 8 ohms as stated by manufacturer) into one of my 8 ohm Lowther speakers. I add a BSC circuit with an elevated parallel resistance to balance the SPL response and now the resistive load is approaching 16 - 20 ohms. If you ratio to get the power the amp will deliver, assuming that it is linear with resistance, then my 200 watt amp into 8 ohms is now an 80 watt amp into 20 ohms. This amp works well with the Lowther but suppose I am not using such an efficient driver ..... I want to be able to drive any speaker load.
I like having extra power, it gives me great flexibility in my speaker designs. I am also really interested in the monoblocks since this will allow me to put the amp right next to the speaker and have a very short speaker cable.
Those are some of my thoughts,
Martin
Previous Topic: Speakers for Dared MP-7
Next Topic: Power Tapered to 12 drivers of 4ohms
Current Time: Mon Nov 16 06:21:10 CST 2026
