Home » Audio » Source » Any thoughts on a Denon DP-2000?
Any thoughts on a Denon DP-2000? [message #12778] Sat, 11 February 2006 18:46 Go to next message
MWG is currently offline  MWG
I have a DP 35 with a Shure M97xE and it sounds ok but I'd rather have something a little nicer looking than the all plastic model. Thank you.
Re: Any thoughts on a Denon DP-2000? [message #12780 is a reply to message #12778] Sun, 12 February 2006 07:59 Go to previous messageGo to next message
What about the 62l? Or the 52L?
Re: Any thoughts on a Denon DP-2000? [message #12781 is a reply to message #12780] Sun, 12 February 2006 10:10 Go to previous messageGo to next message
I would love to have one but they are considerably more money than this model. I'm not familiar enough with Denon TT's to know which is the better model. I know that the double digit models get better as the numbers increase to the 62 but that's the extent of what I know Basically I'm looking for something that is quiet and looks halfway decent.
Re: Any thoughts on a Denon DP-2000? [message #12782 is a reply to message #12781] Sun, 12 February 2006 12:54 Go to previous messageGo to next message
Are you looking for input or do you have your mind set on Denon tables?
Re: Any thoughts on a Denon DP-2000? [message #12784 is a reply to message #12782] Sun, 12 February 2006 19:56 Go to previous messageGo to next message
Actually I'm open to about anything that will be better than what I have. What I have for equipment is a C-26 preamp and a MC-275 amp. The main speakers are Altec Valencias. I have thought about a basic Rega 3 or something like that but I know nothing about TT's. So I haven't rushed right out and bought one I'm not looking for absolute sound here, just decent sound.
Re: Any thoughts on a Denon DP-2000? [message #12786 is a reply to message #12784] Mon, 13 February 2006 08:00 Go to previous messageGo to next message
Man; you have decent sound! Thats a nice Vintage system that probably plays music better than 95% of everything else out there.
There are; as I see it some good choices you could make if your budget is tight. You could try an older table like a Thorens with the crappy Thorens arm for now.
I like all of the 1600/1700/1800 Technics tables because they have the good arm and are built like tanks, very speed stable and troublefree. And they sound pretty good. You can get them off E-Bay for 150$ usually with a decent cartridge. They retain their re-sale value also.
If you wish to go new; the Rega is a good table but after paying full price you may hit the 450$ mark. And truthfully; the least expensive Rega probably doesn't sound any better than the Technics does. Maybe worse with worse wow and flutter specs.
Re: Any thoughts on a Denon DP-2000? [message #12787 is a reply to message #12786] Mon, 13 February 2006 20:04 Go to previous messageGo to next message
Thank you for the suggestions. I'll start looking for something like that. I'm not a E-bay person. I watch CL a lot and with a TT I'd rather pick it up myself. Also than you for the system compliment. It's one reason I know little or nothing about anything else. After i bought that in the early 70's I was happy with the sound and never changed those items. I went through tape decks and TT's but kept the electronics & speakers. All I know about music & sound is what I like and don't like All the finer points of the hobby escape me
Re: Any thoughts on a Denon DP-2000? [message #12788 is a reply to message #12787] Tue, 14 February 2006 12:31 Go to previous messageGo to next message
I don't know; I think those are the fine points. If buying off epay is not an option there are some pretty fair used dealers out there.
Turntable Factory has fair prices for Vintage Tables.
Re: Any thoughts on a Denon DP-2000? [message #12789 is a reply to message #12788] Fri, 17 February 2006 17:14 Go to previous messageGo to next message
Ever hear of a Mitsubishi DP 52? Same letters and numbers as a Denon model. I couldn't find anything on Google about it.
Re: Any thoughts on a Denon DP-2000? [message #12790 is a reply to message #12789] Fri, 17 February 2006 17:16 Go to previous messageGo to previous message
Is that the model with the Tangential Tonearm? Big heavy black unit with an arm similar to the old Rabco?
Previous Topic: Manualblock
Next Topic: broken needle
Current Time: Sun Nov 22 14:38:31 CST 2026
