Home » Audio » Speaker » Jbl 2226h pair for subwoofer
Jbl 2226h pair for subwoofer [message #85913] Tue, 22 August 2017 18:00 Go to next message
leimahmood is currently offline  leimahmood
Hey every one
I have jbl 2226h pair want to make subwoofer one jbl 2226h in one box need best box dimension have crown k2 power
My room is 13w 16l 8h
Thanks
Re: Jbl 2226h pair for subwoofer [message #85917 is a reply to message #85913] Wed, 23 August 2017 09:15 Go to previous messageGo to next message
Put them in a 10ft3 box tuned to 40Hz with plenty of duct area. An example would be two 6" diameter ports, each 5" long or four 4" diameter ports, each 5-1/2" long. Brace the cabinet well.
Re: Jbl 2226h pair for subwoofer [message #85925 is a reply to message #85917] Thu, 24 August 2017 07:11 Go to previous messageGo to next message
Wayne Parham wrote on Wed, 23 August 2017 09:15
2 2226h in one 10cubic feet box ??
Can u plzz tell me the 10cubic feet dimension in inches and how low it will go thanks
Re: Jbl 2226h pair for subwoofer [message #85927 is a reply to message #85925] Thu, 24 August 2017 09:16 Go to previous messageGo to next message
Yes, put a pair of 2226 drivers in a 10ft3 box. Dimensions aren't critical, provided it's a rectangular box with no single dimension extremely long. I'm not concerened about internal standing waves above 100Hz because it's a subwoofer, so you'll low-pass it.
Re: Jbl 2226h pair for subwoofer [message #85928 is a reply to message #85927] Thu, 24 August 2017 12:23 Go to previous messageGo to next message
Want dual separate subwoofer
Read jbl pdf they recomended for a single 4 cubic feet tune to 40hz
On some internet search some are recommended 5 cubic
Feet i just want is musical
Re: Jbl 2226h pair for subwoofer [message #85930 is a reply to message #85928] Thu, 24 August 2017 14:52 Go to previous messageGo to next message
If you want a subwoofer cabinet for a single JBL 2226H, then make a 5ft3 box tuned to 40Hz.
Re: Jbl 2226h pair for subwoofer [message #85931 is a reply to message #85930] Thu, 24 August 2017 15:11 Go to previous messageGo to next message
I m total noob with diy thing its my first diy sub
Can u plzz tell me 5cubic feet box dimension in inches whit ports in inches thank
Re: Jbl 2226h pair for subwoofer [message #85933 is a reply to message #85931] Thu, 24 August 2017 16:58 Go to previous messageGo to next message
Make the box 35" wide x 22" tall x 13" deep. Use two 4" diameter ports that are 5-1/2" long. Use 3/4" or 18mm Baltic Birch or MDF. Brace well using cross-braces (front-to-back and side-to-side) on each side of the woofer along the 35" dimension. The braces can be made using scrap cut from the panels.
Re: Jbl 2226h pair for subwoofer [message #85939 is a reply to message #85933] Fri, 25 August 2017 04:45 Go to previous messageGo to next message
This box is tune to 30hz ??
Re: Jbl 2226h pair for subwoofer [message #85941 is a reply to message #85939] Fri, 25 August 2017 09:18 Go to previous messageGo to previous message
40Hz.
Previous Topic: Two good deals on speakers
Next Topic: Will they get smaller?
Current Time: Tue Oct 20 22:19:51 CDT 2026
